  4. Car Updates / Progress
  5. My DD, ongoing project.
20 Posts 10 Posters 5.7k Views
  • JohnWJ Offline
    JohnWJ Offline
    JohnW
    Here's my little hatch. Used to be svxAL's IIRC.
    Engine:
    d16a6 block, d16y8 head swap, y8 head gasket, y8 timing belt.
    11.1:1 Cr
    d16a6 throttle body, intake manifold, injectors
    d16y8 distributor
    short ram intake (not in pic)
    ebay 4-2-1 header
    frankensteined ebay exahaust (originally for CRX)
    OBX adjustable cam gear.
    Short throw shifter kit w/ mad tyte shift knob yo.
    Electric stuff:
    MPFI conversion
    OBD1 conversion w/ DIY conversion harness
    Added vtec wiring, 4 wire o2, etc.
    converted and chipped p28 spec ecu w/ datalogging, ostrich
    RTP
    I think thats about it. All work was done by me, with no help except for the peeps on d-series.org, pgmfi, and honda-tech. All the wiring is soldered, loomed.
    I'm using crome to tune and running a p30 basemap w/ p2p fuel map, running super rich. The timing is alllll fucked up, due to several factors including deck height, y9 cam gear offset, weird ass p2p ignition timing. I got it close and the car runs fine but doesn't make the power I think it has the potential to make, and won't until I get it on a dyno.
    I've put basically all my time into the motor, so the car still needs shocks, brakes, tires, paintjob etc. I've got a bunch of other stuff sitting here like a crower stage 2 cam, dsm injectors, bigger fuel pump, and a disc brake conversion which I need bigger wheels for. I'll get that stuff done whenever time permits.
    This build has been a real pantload. I learned soooo much though doing it myself. I've gained alot of confidence in my wrenching abilities.
    I'm jonesed to get it on a dyno and get the timing and fuel maps right but that might not happen until next spring, I don't know. As it's tuned now, it's not even quick, i've never revved it out, never raced anyone, and I won't either, so I have no idea how quick it will be at this point.
    Any questions, comments?
    90 Civic DX hatch
    D16a6/y8 mini me
      I thought you were dead. Sweet project.
        umm, why not just run a stock p28 map. it will be close.
        I ran a stock b16 ecu on my mini-me and it ran just fine i had a comp cam in it also.
        • svxALS Offline
          svxALS Offline
          svxAL
          god I miss that car!!
          94 Subaru SVX FWD
          subaru-svx.net
          1999 silverado
          • JohnWJ Offline
            JohnWJ Offline
            JohnW
            cuz the differences between the p28 and p2p fuel maps were substantial enough that I thought it would be better to run the p2p fuel maps considering that i needed to run more fuel with the higher compression anyway. it really wasn't that much work to import the p2p map to the p28.
            for some reason i cannot for the life of me get a p30 rom to run on my ecu, i get code 36 which is supposed to be traction control or something on a jdm ecu, which i obviously dont have, and i cant get rid of that code. i'd like to have the use of 2 step and no lift to shift tho. oh well.
            90 Civic DX hatch
            D16a6/y8 mini me
            • JohnWJ Offline
              JohnWJ Offline
              JohnW
              thanks!
              90 Civic DX hatch
              D16a6/y8 mini me
                It just sounds like your making more work for yourself. The 2 step and no lift shift also sound funny for a extremely mild mini-me build.
                I'm not trying to insult you i just don't see how you will ever use those features.
                  sweet build John!!
                  • JohnWJ Offline
                    JohnWJ Offline
                    JohnW
                    yeah, probably, but now I know how to export a fuel table to one of a different size, amirite?
                    as for the plugins? what, you've never been curious? i'd like to be able to try them for myself rather than just seeing how they work on paper, but i can't, and it's frustrating. i'd also really like to see an antilag plugin work as that is a nice piece of programming.
                    if i wanted to make things easier for myself i could have put on a z6 head instead of the oddball y8, bought an obd conversion harness instead of making it myself, bought a chipped and vtec added ecu instead of pissing around with that (to be fair I did ruin the first p28 I had. i somehow broke the o2 sensor functions) , had someone else do the work, and myriad other things that would have saved my ever growing bald spot. hell, i could have just slapped an intake, header, and exhaust on the a6 with no mpfi conversion and called it a day. That wasn't really the point tho.
                    The point was to get in way over my head and dig myself out.
                    I wanted to learn as much as I could on this first build without spending much money. I'm still very cheap, that hasn't changed. I came up with the idea for the setup I wanted based on the amount of DIY work I could do cheaply to get it there.
                    I had never swapped a head before or even seen it done. Nick or Kevin (not sure who actually did it) were nice enough to swap the head on my dsm for cheap when my balance shaft belt went and got into the timing belt.
                    I didn't know that changing obd systems was even feasible, or why anyone would want to in the first place. I didn't know how mechanical and ignition timing works, or why I would need to mess with them. Crome and Uberdata looked like a pile of numbers and bullshit when I started out.
                    My tuning of the dsm consisted of porting the exhaust side of the turbo, getting a MBC, a bigger fuel pump, and chasing boost leaks. Not too complicated, but i still think with a good trans and clutch that car could have ripped out some good numbers.
                    And yeah, might be a 'mild' build, but i'd say it's pretty good for a noob.
                    After I get this all tuned and whatnot, and possibly down the track a few times, I might try building the bottom end, and put the stuff I have sitting around on.
                    On the other hand, this car needs alot of work still. It needs tires, brakes, and shocks before winter sets in which i'll need to come up with the money for. Sometime over the spring/summer the honda rot on the rear fenders started and is creeping it's way from barely noticable to annoying. So I don't know how much more money I really want to put into it. I've always secretly wanted a white fox body mustang gt tho, so that might be a possibility. Or maybe another 1g DSM. I dunno.
                    90 Civic DX hatch
                    D16a6/y8 mini me
                    • JohnWJ Offline
                      JohnWJ Offline
                      JohnW
                      King Ricer;288602 wrote:
                      sweet build John!!
                      Appreciated!
                      90 Civic DX hatch
                      D16a6/y8 mini me
                        i dig it, ive always like this car. pics of the whole vehicle?
                        • JohnWJ Offline
                          JohnWJ Offline
                          JohnW
                          Looks the same, except cracked primer on the front quarters, a rust spot on the drivers side rear quarter, center console torn up from some fucking jackass who really wanted my deck and thought tearing the heater controls out was a good way to get it. i'll try and take pics tomorrow tho.
                          90 Civic DX hatch
                          D16a6/y8 mini me
                          • JohnWJ Offline
                            JohnWJ Offline
                            JohnW
                            Wheels and tires. Did brakes, new struts, misc crap.
                            90 Civic DX hatch
                            D16a6/y8 mini me
                            • JohnWJ Offline
                              JohnWJ Offline
                              JohnW
                              I have an intake. $25 on ebay, you definitely get what you pay for. The red and blue made me hurl at first but it's kind of growing on me. I may paint the pipe black, and I need to add length so that wire can go underneath, but overall it's ok.
                              90 Civic DX hatch
                              D16a6/y8 mini me
                              • gsrEKG Offline
                                gsrEKG Offline
                                gsrEK
                                i have itbs that i was goin to use on a sohc laying around for sale and a crower stage 3 sohc cam also if interested
                                2009 Yamaha Zuma 125, gas HOG
                                2008 Honda Fit daily
                                A s2k
                                1991 Honda civic DX Mint SOLD
                                1988 Mitsubishi Mighty max
                                > BlackEJ8;233529 wrote:
                                • JohnWJ Offline
                                  JohnWJ Offline
                                  JohnW
                                  Not really looking for anything that crazy. Thanks though!
                                  90 Civic DX hatch
                                  D16a6/y8 mini me
                                  • blackcherryTSiB Offline
                                    blackcherryTSi
                                    psssshhh.. how much for the cam? lol and car looks good!.... gangsta ef love
                                    1995 Honda Civic
                                    • gsrEKG Offline
                                      gsrEKG Offline
                                      gsrEK
                                      not for sale to you
                                      A s2k
                                        gsrEK;315162 wrote:
                                        not for sale to you
                                        ouch!
                                        • F Offline
                                          F Offline
                                          ForestGreen
                                          looks good
