  3. Run Your Mouth
  4. What will be the next BIG THING....??
245 Posts 43 Posters 24.6k Views
  • inspector01I
    inspector01I
    DrifterExtreme;295301 wrote:
    Well it just got a new engine and it blew a hg in 25 miles, ask me how the fuck that happens. idk So it's back in the shop and i'm waiting on it again.
    Mo Boost.....
    • DrifterExtremeD
      DrifterExtremeD
      weshole;295302 wrote:
      What shop is it at?
      Corwin honda.
      • wesholeW
        wesholeW
        Gotta love warranty
        • T
          T
          Trafik Jamz
          weshole;295084 wrote:
          I will be the
          NEXT
          BIG
          THING!!!
          R3k0Nyz3 Muthrfukr
          You all may as well jump on board while im still cheap. woohooo!!!
          Ok Brock Lesnar......
          Btw, you will always be cheap...and easy...
          701.541.3484
          • wesholeW
            wesholeW
            Yup.
            • ruthless351R
              ruthless351R
              ruthless351
              That sucks man! That old motor went to hell and didnt make it back in one piece. Hope it all works out. BTW matt.......did you ever show the carnage from the engine???
              • DelSlowD
                DelSlowD
                Corwin Honda on Leak down tests: "fuck em, we don't need em. Its much faster to just not do them."
                • RexwagonR
                  RexwagonR
                  welcome back del slow from ban!!!!!!!!!!!
                  • DelSlowD
                    DelSlowD
                    /hug
                    • bubbaB
                      bubbaB
                      blackcherryTSi;295161 wrote:
                      oh you have not heard? ask mr. bubba what he heard/saw on his balcony ha.... rumble rumble bov sliiiiide bov sliiiiide bov lol in that order
                      Its true... i seen it with my own eyes...
                      • SPANISH-RICES
                        SPANISH-RICES
                        delslow;295333 wrote:
                        corwin honda on leak down tests: "fuck em, we don't need em. Its much faster to just not do them."
                        his warranty does not pay for diagnostics items on a new motor that was supposed to be good. Why would someone assume that it had a bad headgasket? Shit happens with used motors, you cant expect everything to be wrong and pre diagnose something without concerns.
                        the corwin service warranty is covering the repair from the motor now so it really doesnt matter. its being taken care of the way it should be.
                        • DrifterExtremeD
                          DrifterExtremeD
                          what about my $200 in diagnosing a fuse? it took a tech 2 hrs to find a fuse was missing? seriously not impressed at this point.
                          • itRfanI
                            itRfanI
                            itRfan
                            still no vids...still no happening..lol
                            -weshole
                            • Z
                              Z
                              zex-ftw
                              Do any of you tuner wannabees even know how to do a leak down test. Obviously not since a leak down test is to check for sealing valves and rings. So stop acting like you know what your talking about, and lay off. If it wasnt for corwins matt would be with out a motor hes lucky hes getting what he got. Im sure the warranty company wouldnt mind hearing how the motor was taking out of the car for a year before they submitted a claim.
                              • T
                                T
                                Trafik Jamz
                                Uhhh.....you do realize that a leak-down tester can test bad head gaskets too, right? Perhaps you are the one who should stop acting like you know what you are talking about and lay off.
                                http://en.wikipedia.org/wiki/Head_gasket wrote:
                                Gasket problems
                                Occasionally, the compression in the cylinder will cause a leak to form in the gasket and the gasket will have to be replaced, or severe damage can take place (a "blown" head gasket). This problem has been exacerbated by the use of aluminum rather than iron cylinder heads; while lighter than iron, aluminum has a much greater thermal expansion rate, which in turn causes a great deal more stress to be placed on the head gasket. Engine makers have responded to this by adding a non-stick coating such as Teflon to the surface of the head gasket.
                                If the gasket fails, a variety of problems can occur, from compression loss (leading to power reduction, or a rough engine), to exhaust gases being forced into the cooling system, leading to the engine overheating and increased engine wear due to the motor oil being mixed with antifreeze. Coolant can leak into the cylinders, causing the exhaust to issue steam[3] and the catalytic converter to be damaged. If a very large amount of coolant does this, hydrolock can occur, causing extensive engine damage. Sometimes, all that may happen when a head gasket is blown is excessive steam erupting from the tailpipe; yet the engine may act and drive like normal, until all the coolant is gone and the engine overheats.
                                A damaged head gasket can cause compression to leak between cylinders.
                                Head gasket condition can be investigated by checking the compression pressure with a pressure gauge, or better, a leak-down test, and/or noting any indication of combustion gasses in the cooling system on a water-cooled engine. Oil mixed with coolant and excessive coolant loss with no apparent cause, or presence of carbon monoxide or hydrocarbon gases in the expansion tank of the cooling system can also be signs of head gasket problems.
                                Driving with a blown head gasket (if possible) can cause additional extensive damage due to overheating or loss of lubrication.
                                Blue exhaust smoke may be indicative of oil burning. White exhaust smoke is an indicator of coolant burning, another sign of head gasket wear.
                                701.541.3484
                                • wesholeW
                                  wesholeW
                                  ZEX-FTW huh? 2 posts in how many years? Ya, a real asset to the site.
                                  • ruthless351R
                                    ruthless351R
                                    ruthless351
                                    I was wondering the same thing. Im still gunna go with abuse that took out the engine but hey..... what do i know? Matt is extremely lucky he is getting what he is getting.
                                    • SPANISH-RICES
                                      SPANISH-RICES
                                      im trying to be civil, im not trying to get into a heated debate. all im saying is that wills comment was was uncalled for. the fuse thing i dont know much about but i remember hearing a little about it and not being impressed also. sometimes flat rate works out for the customer sometimes for the tech, thats the nature of flat rate.
                                      • Z
                                        Z
                                        zex-ftw
                                        wow you aint got a clue what your talking about anybody can copy and paste how to test for a bad head gasket. unless the motor is totally running like shit and smoking a leak down test isnt goin to tell you shit. and in matts case his engine was running fine. plus it was a used motor from a junk yard, you got no clue how a dealership works if a tech isnt getting paid to look at it he isnt working on it. all they were suppose to do was install the used motor that was sent to them not diagnose underlying conditions.
                                        • wesholeW
                                          wesholeW
                                          Look out!! Mr. goodwrench has spoken. It must be gosphel.
