Dave, Matt, Bill
I have 2- 255hp walbo intank fuel pumps.. should be good for 700 or more.
aliengotpsi;297002 wrote:
.. should be good for 700 or more.yeah then one shits under full power and bye bye engine
Id rather have just one pump quit and loose fuel altogether than have one pump out of the two quit and let the engine still be running in possible serious lean condition
XJHEAD;297042 wrote:
I was running a -8 N/A and spray. Now a -10DaveH;297058 wrote:
-10 AN here also.lol that means -8 for me,
what regulators for you guys, and do you have a filter pre and post pump?
I should have just named this thread ..."the really fast guys' fuel systems" haha
thanks
zbrown;297065 wrote:
What regulators for you guys, and do you have a filter pre and post pump?I had the Aeromotive on the Cobra, when I had two pumps on that it was not returning enough of the fuel to the return line. I borrowed Dave's Weldon and it cleared that right up. The Orange car had a Weldon on it. With both pumps running base pressure goes up maybe 2-3 lbs at idle. Either one should be fine. Also run two filters, one before the pump and one after.
Christian;297072 wrote:
-10 AN for me too and -8 back . Just do it right the first time so you only have to do it once.Please read the quote below..:icon_rabbit:
I should have just named this thread ..."the really fast guys' fuel systems" hahathanks
I run an Aeromotive Pro pre-filter and a Aeromitive standard post filter. Braided line the whole way, no hardlines.
I have -12AN line from the fuel cell to the pump, then -10AN from the pump up to the engine bay, I have a Y-block in the engine bay where it splits to two -8AN lines and each -8AN line goes to an end of the fuel rail. I got the Weldon 2040 regulator.
Aeroquip Push-lock is a cheaper alternative from cell/tank to the engine bay. It is a very durable hose.
http://www.aeroquip.cc/fbv0800fc332-08aeroquipsocketlesspush-onhosehightempfc332-8.aspx -
XJHEAD;296969 wrote:
I have a Weldon 2035. Pressure started dropping at about 1250 rwhp at the track. I added my old Accel DFI pump that I used on the Cobra. It flows about the same as the 2035. They aren't too bad if mounted properly. Here is the video of the Weldon that was bolted right to the car with no isolators.http://www.youtube.com/watch?v=8Qc07FKciTc
If I can make room I am going belt drive this winter.. I don't like the idea of two pumps.
Sounds like tornado sirens. :fork:
DaveH;297088 wrote:
I run an Aeromotive Pro pre-filter and a Aeromitive standard post filter. Braided line the whole way, no hardlines.I have -12AN line from the fuel cell to the pump, then -10AN from the pump up to the engine bay, I have a Y-block in the engine bay where it splits to two -8AN lines and each -8AN line goes to an end of the fuel rail. I got the Weldon 2040 regulator.
thanks
http://www.aeroquip.cc/fbv0800fc332-08aeroquipsocketlesspush-onhosehightempfc332-8.aspxI have always wondered about the push-lock stuff, never knew if it was any good so i have never tried it
maybe I'll give it a try, thanks
