  4. Dave, Matt, Bill
Dave, Matt, Bill
53 Posts 17 Posters 5.4k Views
    and how big of line are you guys running from the pump forward?
    • 63vette6 Offline
      63vette6 Offline
      63vette
        63vette;297007 wrote:
        that takes more power to operate than my engine makes... lol
        • XJHEADX Offline
          XJHEADX Offline
          I was running a -8 N/A and spray. Now a -10
            -10 AN here also.
              DaveH;297058 wrote:
              -10 AN here also.
              lol that means -8 for me,
              what regulators for you guys, and do you have a filter pre and post pump?
              I should have just named this thread ..."the really fast guys' fuel systems" haha
              thanks
              • ChristianC Offline
                ChristianC Offline
                Christian
                -10 AN for me too and -8 back . Just do it right the first time so you only have to do it once.
                Playtime Performance
                06 F-150 Lariat
                • XJHEADX Offline
                  XJHEADX Offline
                  zbrown;297065 wrote:
                  What regulators for you guys, and do you have a filter pre and post pump?
                  I had the Aeromotive on the Cobra, when I had two pumps on that it was not returning enough of the fuel to the return line. I borrowed Dave's Weldon and it cleared that right up. The Orange car had a Weldon on it. With both pumps running base pressure goes up maybe 2-3 lbs at idle. Either one should be fine. Also run two filters, one before the pump and one after.
                  Please read the quote below..:icon_rabbit:
                  thanks
                    You guys run and bend hardline the length of the car or just run SS braided the whole way up?
                    thanks for the input:icon_thumleft:
                      I run an Aeromotive Pro pre-filter and a Aeromitive standard post filter. Braided line the whole way, no hardlines.
                      I have -12AN line from the fuel cell to the pump, then -10AN from the pump up to the engine bay, I have a Y-block in the engine bay where it splits to two -8AN lines and each -8AN line goes to an end of the fuel rail. I got the Weldon 2040 regulator.
                      • XJHEADX Offline
                        XJHEADX Offline
                        Aeroquip Push-lock is a cheaper alternative from cell/tank to the engine bay. It is a very durable hose.
                        http://www.aeroquip.cc/fbv0800fc332-08aeroquipsocketlesspush-onhosehightempfc332-8.aspx
                          XJHEAD;296969 wrote:
                          I have a Weldon 2035. Pressure started dropping at about 1250 rwhp at the track. I added my old Accel DFI pump that I used on the Cobra. It flows about the same as the 2035. They aren't too bad if mounted properly. Here is the video of the Weldon that was bolted right to the car with no isolators.
                          http://www.youtube.com/watch?v=8Qc07FKciTc
                          If I can make room I am going belt drive this winter.. I don't like the idea of two pumps.
                          Sounds like tornado sirens. :fork:
                            Parker;296974 wrote:
                            Silly electronic fuel pumps...
                            Silly carburetors
                              thanks
                              I have always wondered about the push-lock stuff, never knew if it was any good so i have never tried it
                              maybe I'll give it a try, thanks
                                push lock works very good...
                                  Parker;297153 wrote:
                                  push lock works very well...
                                  fxt
                                    zbrown;297158 wrote:
                                    fxt
                                    Oh, you got me good fucker.....
                                      Stupid farmers...
                                      • 00Ws6TransAm0 Offline
                                        00Ws6TransAm
                                        zbrown;296962 wrote:
                                        How loud are the Weldon pumps? is the pump like you have good for continuous use or no?
                                        I picked up a Magnafuel 4301
                                        Any of you heard good or bad about these pumps?
                                        FWIW
                                        I have been using that exact pump for the last 2 years. It is a great pump, I had one issue with it overheating, but after sending it in and them fixing for free its been flawless. It was 95 when it overheated, i havent heard of such problems with other users though. There was older style wear plates in there that expanded and locked it up when overly hot.
                                        I have a 74micron pre filter and a 40micron post filter. I have part #'s if you want and it will save you money buying direct rather than through a vendor.
                                        -8feed and -6 return (Stainless all the way)
                                        Line runs in one rail across the front through the other, out the back,and into the magnafuel fuel pressure regulator.
                                        Depending on your power goals you may want to increase line sizes.
                                          00Ws6TransAm;297656 wrote:
                                          FWIW
                                          thanks for the info! glad to hear you have had good luck with it.
                                          I already picked up my plumbing supplies sadly 😞 ... got a magnafuel 74 micron and 10 micron filters... and the big magnafuel 9950 regulator with -8 return
                                          some of you may think i am retarded but i plan to run my regulator in the back of the car....going to run a high static fuel pressure and un-referenced.
                                          I like the simplicity in the engine bay with no fuel plumbing there... i will see how it works like that, i can always change to referenced
                                          will be -10 to the pump... -8 to the FPR.... -8 from FPR up to the front rail... and a -8 return from the FPR right to the tank
                                          -8 will support 1k hp.... I am not crazy like some of you guys so it will suffice 😉
