New Stuff
are you going to race this car when done?
probably fail because you didnt buy it at macs
I have to say i am quite surprised.... Luke and I figured the complete Granny setup would weigh around 30lbs more than the complete NA IRS setup.... we were wrong......... in a good way!
YES... I did forget to take the rotors off the IRS, but i also forgot to weigh the subframe and diff retaining caps... so it would be about a wash. And YES, I zeroed the scale with the weight of the lumber in the IRS pic
So...
first stock open(welded) NA IRS
and weight of 220lbs
.now the complete 8.8 axle (its cold and i breathed... lol)
and a weight of 135lbs
plus complete Granny TA mounting kit
and a weight of 56lbs
.So 220lbs for the IRS
and 191lbs (135+56) for the solid 8.8
~30lbs really was surprised as i was saying
I am guessing a TII IRS setup is going to be what? 10lbs heavier? more or less than that?
anyway, thought you guys would be curious to see some actual numbers....
