  4. New Stuff
New Stuff
461 Posts 56 Posters 69.2k Views
    aliengotpsi;296204 wrote:
    are you going to race this car when done?
    maybe...
    atleast once since i need to make a pass faster than 11.87... hopefully it will atleast run that fast, maybe it wont....
      probably fail because you didnt buy it at macs
        lol, very possible outcome
        just about done....
        there is frost on the heads and block, that is why it looks messed up
          I have to say i am quite surprised.... Luke and I figured the complete Granny setup would weigh around 30lbs more than the complete NA IRS setup.... we were wrong......... in a good way!
          YES... I did forget to take the rotors off the IRS, but i also forgot to weigh the subframe and diff retaining caps... so it would be about a wash. And YES, I zeroed the scale with the weight of the lumber in the IRS pic
          So...
          first stock open(welded) NA IRS
          and weight of 220lbs
          legacy image.
          now the complete 8.8 axle (its cold and i breathed... lol)
          and a weight of 135lbs
          plus complete Granny TA mounting kit
          and a weight of 56lbs
          So 220lbs for the IRS
          and 191lbs (135+56) for the solid 8.8
          ~30lbs really was surprised as i was saying
          I am guessing a TII IRS setup is going to be what? 10lbs heavier? more or less than that?
          anyway, thought you guys would be curious to see some actual numbers....
            What did that 8.8 come out of?
              out of a fox with these changes
              billet 9" housing ends
              forged 9" style 31 spline axles
              o-ring style 9" axle bearings and retainers
                Excellent. Should be better than Parkers car. 😄
                  lol, if nothing else give him some motivation to do something with his
                    I was told that he moved it from one shop to another a while back, does that count as doing something with it, lol...
                      Hey, I moved it twice this year.
                        my fuel pump showed up, Magnafuel 4301
                        supposed to support 1000whp on gasoline with forced induction so it should support enough for me on e85
                          Still weak
                            That's as much as my car has moved since i bought it... but yours was probably under it's own power, lol...
                              bahaha, I'm not putting money on that...
                                it was above 0* today so i did the cold side aluminum stuff, don't know what BOV i am going to use yet
                                  im gonna have sex with that car when you bring it here
                                  • beachbum_jonB Offline
                                    beachbum_jon
                                    nice hood prop..
                                    -John Adams, 1735-1826-
                                      beachbum_jon;298407 wrote:
                                      nice hood prop..
                                      who doesn't like rust?
                                        beachbum_jon
                                        adds character
                                          got my IAT moved to the back of the intake so you cant see it or the wiring.
                                          Also got NASTY billet rails, they are O-ring instead of NPT, and for the really short ls3/ls7 injectors
