  4. 2g DSM Help?
2g DSM Help?
12 Posts 4 Posters 705 Views
  • s13coupeS Offline
    s13coupeS Offline
    s13coupe
    Ok guys i have been tossing up the idea of getting a 96 gsx from a guy in town. The problem with the car is that it has the JDM Cyclone 6bolt with no ECU/ECM. So.......
    Does anyone know where i can get the Cyclone ECU/ECM.
    Or....
    Can you switch the intake manifolds & ECU to the OEM computer???
    Any help is appreciated. Thanks in advance!!!
    '87 300zx Turbo - summer car
    '90 300zx RB25 - drift car
    '95 Civic sedan - hooptie
      I'm pretty sure the cyclone manifold is completely vacuum controlled aka no ecu required to run it. If he says its running rough, BE CAUTIOUS. I'm fairly certain I've seen this ad myself. Get the motor checked out and ditch the cyclone mani anyway.
      • D S ohMD Offline
        D S ohMD Offline
        D S ohM
        This.
        I wanna go fast!
        • s13coupeS Offline
          s13coupeS Offline
          s13coupe
          He says it spits and sputters cuz the ecu is 'junk'...... What could be the real reason?
            Capacitors go bad in the ECU's all the time, atleast in 1G's. Save yourself the trouble, find a cheap ecu and bring it with...take it for an extended test drive, through it in there and see how she does. Check the compression and timing as well(check the belt alignment as well, as 1 tooth is enough to have issues). If you can't do all of this, spend the money and take it to a shop..DSMs are a dime a dozen and buying a shitty one is just more trouble than its worth!
            • s13coupeS Offline
              s13coupeS Offline
              s13coupe
              Well im friends with the guy so im pretty sure i could give it the rundown and he wouldnt care.
              Question: So does it to be need the cyclone ecu to run that beotch or can it be any 4G63T ecu?
                Cyclone is a vacuum controlled manifold, get yourself a 96 AWD ECU...
                • s13coupeS Offline
                  s13coupeS Offline
                  s13coupe
                  aww shit i didnt read the other post well enough sorry man.
                  i have been looking havent found much yet but maybe ill get lucky
                    Check ebay or DSM tuners.
                    • D S ohMD Offline
                      D S ohMD Offline
                      D S ohM
                      www.dsmtrader.com
                      I wanna go fast!
                        aliengotpsi
                        You can take out the butterflys in the manifold .
                        Why do you think the ECU is bad? Just because is spits and sputters means the ECU is bad? Then I guess my Evo ECU is shot!
                        Here you go http://www.magnusmotorsports.com/tech/1gina2g.pdf
                        Go to this site and it will tell you everything you need to know about 1g jdm engine in a 2g!
                        Do a step by step and double check everything!
                        Your welcome
                        Kevin Smith
                        Straightlinedetailing.com
                        • s13coupeS Offline
                          s13coupeS Offline
                          s13coupe
                          Your welcome
                          I am just going off of what the owner said man, but ill give that shiz a try then
