  4. Winter mods 2009-10
Winter mods 2009-10
98 Posts 39 Posters 8.1k Views
  • XJHEADX Offline
    XJHEADX Offline
    XJHEAD;296351 wrote:
    Will be doing the following;
    Mini-tub to get some 315-60-15 Radial tires to fit.
    Crank trigger for the ignition.
    Would like to;
    Possibly upgrade to DFI GEN VII fron GEN VII
    Get rid of the two electric fuel pumps Weldon 2035 and the ACCEl pump and get a belt drive.
    Drop fuel pressure from 60 psi to 43 psi and get rid of the 160 lbr's and put in some 225's
    2-speed 400 or a glide
    will add to the list later.
    The mini-tub kit showed up and the tires are on order. Here is a picture of a 315 vs a 325, big difference.
      I think you meant lb/hp. 🙂 Otherwise you are in top fuel dragster territory.
      Bassplayer;297068 wrote:
      Ha yeah I didn't really mean that like literally. It's only ~8.5HP/lb, hopefully less than 6 with nitrous.
        holy balls, what is the OD difference on those
        edit saw it was only 2" difference, looks like more
        • z31Z Offline
          z31Z Offline
          z31
          How is this tire change going to be gearing wise?
          • XJHEADX Offline
            XJHEADX Offline
            It will be a like a 2.87 gear. If I want it to be the same I would have to get some 3.31 gears. I'll worry about a gear change later if needed. I think I'll be ok with what I am running. I need the extra gearing to be the first in the 180's anyways..:icon_rr:
            • z31Z Offline
              z31Z Offline
              z31
              Fidanza 11lb aluminum flywheel
              South Bend DXD stage 5 clutch
              Balance clutch and flywheel as an assembly
              Intercooler and piping install
              Blow off valve
              88t front rotors and twin pistion calipers (bigger)
              88t rear calipers and vented rotors (bigger)
              88t rear control arms :icon_bigsmurf:
              • 00Ws6TransAm0 Offline
                00Ws6TransAm
                Grr;296394 wrote:
                finish wiring, fuel system, finish my headers, get the turbo spinnin (oil lines) and then go destroy the rear axle so i can put a 8.8 in and 275 drag radials. Then it should pull the wheels...
                Regret abandoning your LS motor yet?:)
                Ill have to check your car out, still havent. WE may even have to line them up.
                  Na i hear he misses the LT.....
                    dont think i will ever miss a god damn lt, guess it was pretty good if you get past the electronics. I like my new setup its pretty bad ass
                      00Ws6TransAm
                      Explain...
                      Dont u have a turbo lt1 car now?
                      PM if you want.
                        Tested out some new EMS yesterday, so far pretty happy with it, I think it will be nice. Also doing a bit of body work over the last couple of days, getting it ready to go for spring.
                        • funky_monkey58F Offline
                          funky_monkey58
                          Shave and paint engine bay: Done
                          Replace windshield...:Thought about it
                          Repaint roof...:thought about it
                          Build an exhaust manifold:In process
                          Custom 74mm triple ceramic ball bearing turbo with stainless T4 housing:In process
                          New custom intake manifold:In process
                          Get rid of 3KGT ignitor and msd tach driver for DH61 toyota ignitor: Done
                          Custom -10AN fuel rail: Done
                          Custom crank trigger: Done
                          Full 3.5" exhaust:Thought about it
                          I think that about sums it up.
                            00Ws6TransAm
                            That sounds like some nice power potential?:icon_cheers:
                            What car is this going in? Older supra?
                              funky_monkey58
                              Yeah it is going in my 87.
                              Last year I took out a bearing prematurely, was running a gt4088.
                              This next year I built an engine and switched from race fuel to E85.
                              • Chance91C Offline
                                Chance91C Offline
                                Chance91
                                Big ol snail.
                                  Chance91;297829 wrote:
                                  Big ol snail.
                                  yeah about that....
                                    Holy that thing is freaking HUGE!!!!
                                    • Chance91C Offline
                                      Chance91C Offline
                                      Chance91
                                      Yea yea... Its big for a 1.8... that isn't a honda. Haha.
                                        Lol its planty big for a Miata
                                          So what on there list of things does everyone have/have done so far?? And whats left to be done??
