Winter mods 2009-10
KA-T_240;297047 wrote:
Isn't that overkill for a lil CRXYes :icon_rr: but it's not my DD. Having a 200hp motor in that car is overkill, and that's exactly what I'm going for haha Also I've just always had a place in my heart for pimp wheels with really nice brakes behind them.
Oh yeah and I just bought the brakes so they will be on their way Monday! There goes all my Christmas $.
Bassplayer;297049 wrote:
Yes :icon_rr: but it's not my DD. Having a 200hp motor in that car is overkill, and that's exactly what I'm going for haha Also I've just always had a place in my heart for pimp wheels with really nice brakes behind them.Oh yeah and I just bought the brakes so they will be on their way Monday! There goes all my Christmas $.
what size wheels will u have to run? 15's are about perfect imo.. anything bigger than 16's look just plain gay...
I think DA brakes with good pads/rotors will be good enough, if not i've seen ppl make prelude brakes fit... also a lot cheaper...
zbrown;297054 wrote:
yes... soooooo overkill\Ha yeah I didn't really mean that like literally. It's only ~8.5HP/lb, hopefully less than 6 with nitrous. I hope to be bringing this car to school with me in Ohio over Spring break, and racing it at Mid Ohio Speedway in the summer. It's not made to be a suppidly overpowered Honda, just cheap, fast, and reliable.
bubba;297063 wrote:
what size wheels will u have to run? 15's are about perfect imo.. anything bigger than 16's look just plain gay...I think DA brakes with good pads/rotors will be good enough, if not i've seen ppl make prelude brakes fit... also a lot cheaper...
You have to run 16's on them. I'll be running 16X7 +35 Desmonds. I got a really really good deal on them that I couldn't pass up. Like I said I'm a sucker for good brakes, and these calipers also fit 11" rotors so I can always switch to those if I feel like running a 15" wheel.
XJHEAD;296351 wrote:
Will be doing the following;
Mini-tub to get some 315-60-15 Radial tires to fit.
Crank trigger for the ignition.
Would like to;
Possibly upgrade to DFI GEN VII fron GEN VII
Get rid of the two electric fuel pumps Weldon 2035 and the ACCEl pump and get a belt drive.
Drop fuel pressure from 60 psi to 43 psi and get rid of the 160 lbr's and put in some 225's
2-speed 400 or a glide
will add to the list later.The mini-tub kit showed up and the tires are on order. Here is a picture of a 315 vs a 325, big difference.
z31;297606 wrote:
How is this tire change going to be gearing wise?It will be a like a 2.87 gear. If I want it to be the same I would have to get some 3.31 gears. I'll worry about a gear change later if needed. I think I'll be ok with what I am running. I need the extra gearing to be the first in the 180's anyways..:icon_rr:
Fidanza 11lb aluminum flywheel
South Bend DXD stage 5 clutch
Balance clutch and flywheel as an assembly
Intercooler and piping install
Blow off valve
88t front rotors and twin pistion calipers (bigger)
88t rear calipers and vented rotors (bigger)
88t rear control arms :icon_bigsmurf: -
Grr;296394 wrote:
finish wiring, fuel system, finish my headers, get the turbo spinnin (oil lines) and then go destroy the rear axle so i can put a 8.8 in and 275 drag radials. Then it should pull the wheels...Regret abandoning your LS motor yet?:)
Ill have to check your car out, still havent. WE may even have to line them up.
Grr;297791 wrote:
dont think i will ever miss a god damn lt, guess it was pretty good if you get past the electronics. I like my new setup its pretty bad assExplain...
Dont u have a turbo lt1 car now?
PM if you want.
Tested out some new EMS yesterday, so far pretty happy with it, I think it will be nice. Also doing a bit of body work over the last couple of days, getting it ready to go for spring.
Shave and paint engine bay: Done
Replace windshield...:Thought about it
Repaint roof...:thought about it
Build an exhaust manifold:In process
Custom 74mm triple ceramic ball bearing turbo with stainless T4 housing:In process
New custom intake manifold:In process
Get rid of 3KGT ignitor and msd tach driver for DH61 toyota ignitor: Done
Custom -10AN fuel rail: Done
Custom crank trigger: Done
Full 3.5" exhaust:Thought about itI think that about sums it up.
That sounds like some nice power potential?:icon_cheers:
What car is this going in? Older supra?
00Ws6TransAm;297821 wrote:
That sounds like some nice power potential?:icon_cheers:What car is this going in? Older supra?
Yeah it is going in my 87.
Last year I took out a bearing prematurely, was running a gt4088.
This next year I built an engine and switched from race fuel to E85.
Otherwise you are in top fuel dragster territory.
