  4. Winter mods 2009-10
Winter mods 2009-10
98 Posts 39 Posters 8.7k Views
  • T
    T
    Trafik Jamz
    blackcherryTSi;296719 wrote:
    Subaru- decent wheels, sti wing, double din, tomei arms m7760 turbo w/ accompaning (sp?) mods.... etc
    I know a guy who has all those things 😉 Especially the STi wing. If you have a silver wrx wingless I'd contemplate a trade of the trunk lids.
    701.541.3484
    • BassplayerB
      BassplayerB
      Bassplayer
      I'm currently working on buying a 12.19" Wilwood Big Brake kit, so I guess that goes on the winter mod list for the CRX. :icon_bigsmurf:
      1995 GMC Sierra
      • K
        K
        Isn't that overkill for a lil CRX
        • dubbsyD
          dubbsyD
          dude, endos!
          • BassplayerB
            BassplayerB
            Bassplayer
            Yes :icon_rr: but it's not my DD. Having a 200hp motor in that car is overkill, and that's exactly what I'm going for haha Also I've just always had a place in my heart for pimp wheels with really nice brakes behind them.
            Oh yeah and I just bought the brakes so they will be on their way Monday! There goes all my Christmas $.
            1995 GMC Sierra
            • zbrownZ
              zbrownZ
              Bassplayer;297049 wrote:
              Having a 200hp motor in that car is overkill, and that's exactly what I'm going for haha$.
              yes... soooooo overkill
              • bubbaB
                bubbaB
                what size wheels will u have to run? 15's are about perfect imo.. anything bigger than 16's look just plain gay...
                I think DA brakes with good pads/rotors will be good enough, if not i've seen ppl make prelude brakes fit... also a lot cheaper...
                • BassplayerB
                  BassplayerB
                  Bassplayer
                  zbrown;297054 wrote:
                  yes... soooooo overkill\
                  Ha yeah I didn't really mean that like literally. It's only ~8.5HP/lb, hopefully less than 6 with nitrous. I hope to be bringing this car to school with me in Ohio over Spring break, and racing it at Mid Ohio Speedway in the summer. It's not made to be a suppidly overpowered Honda, just cheap, fast, and reliable.
                  You have to run 16's on them. I'll be running 16X7 +35 Desmonds. I got a really really good deal on them that I couldn't pass up. Like I said I'm a sucker for good brakes, and these calipers also fit 11" rotors so I can always switch to those if I feel like running a 15" wheel.
                  1995 GMC Sierra
                  • XJHEADX
                    XJHEADX
                    XJHEAD;296351 wrote:
                    Will be doing the following;
                    Mini-tub to get some 315-60-15 Radial tires to fit.
                    Crank trigger for the ignition.
                    Would like to;
                    Possibly upgrade to DFI GEN VII fron GEN VII
                    Get rid of the two electric fuel pumps Weldon 2035 and the ACCEl pump and get a belt drive.
                    Drop fuel pressure from 60 psi to 43 psi and get rid of the 160 lbr's and put in some 225's
                    2-speed 400 or a glide
                    will add to the list later.
                    The mini-tub kit showed up and the tires are on order. Here is a picture of a 315 vs a 325, big difference.
                    • DaveHD
                      DaveHD
                      I think you meant lb/hp. 🙂 Otherwise you are in top fuel dragster territory.
                      • zbrownZ
                        zbrownZ
                        holy balls, what is the OD difference on those
                        edit saw it was only 2" difference, looks like more
                        • z31Z
                          z31Z
                          z31
                          How is this tire change going to be gearing wise?
                          • XJHEADX
                            XJHEADX
                            It will be a like a 2.87 gear. If I want it to be the same I would have to get some 3.31 gears. I'll worry about a gear change later if needed. I think I'll be ok with what I am running. I need the extra gearing to be the first in the 180's anyways..:icon_rr:
                            • z31Z
                              z31Z
                              z31
                              Fidanza 11lb aluminum flywheel
                              South Bend DXD stage 5 clutch
                              Balance clutch and flywheel as an assembly
                              Intercooler and piping install
                              Blow off valve
                              88t front rotors and twin pistion calipers (bigger)
                              88t rear calipers and vented rotors (bigger)
                              88t rear control arms :icon_bigsmurf:
                              • 00Ws6TransAm0
                                00Ws6TransAm0
                                00Ws6TransAm
                                Grr;296394 wrote:
                                finish wiring, fuel system, finish my headers, get the turbo spinnin (oil lines) and then go destroy the rear axle so i can put a 8.8 in and 275 drag radials. Then it should pull the wheels...
                                Regret abandoning your LS motor yet?:)
                                Ill have to check your car out, still havent. WE may even have to line them up.
                                • zbrownZ
                                  zbrownZ
                                  Na i hear he misses the LT.....
                                  • GrrG
                                    GrrG
                                    dont think i will ever miss a god damn lt, guess it was pretty good if you get past the electronics. I like my new setup its pretty bad ass
                                    • 00Ws6TransAm0
                                      00Ws6TransAm0
                                      00Ws6TransAm
                                      Explain...
                                      Dont u have a turbo lt1 car now?
                                      PM if you want.
                                      • inspector01I
                                        inspector01I
                                        Tested out some new EMS yesterday, so far pretty happy with it, I think it will be nice. Also doing a bit of body work over the last couple of days, getting it ready to go for spring.
                                        • funky_monkey58F
                                          funky_monkey58F
                                          funky_monkey58
                                          Shave and paint engine bay: Done
                                          Replace windshield...:Thought about it
                                          Repaint roof...:thought about it
                                          Build an exhaust manifold:In process
                                          Custom 74mm triple ceramic ball bearing turbo with stainless T4 housing:In process
                                          New custom intake manifold:In process
                                          Get rid of 3KGT ignitor and msd tach driver for DH61 toyota ignitor: Done
                                          Custom -10AN fuel rail: Done
                                          Custom crank trigger: Done
                                          Full 3.5" exhaust:Thought about it
                                          I think that about sums it up.
