  4. Winter mods 2009-10
Winter mods 2009-10
98 Posts 39 Posters 8.7k Views
    blackcherryTSi;296719 wrote:
    Subaru- sti wing,
    Please don't, or I will make fun of you relentlessly, just ask Travis.....
      inspector01;296891 wrote:
      please don't, or i will make fun of you relentlessly, just ask travis.....
      so true. Worst mod ever.
        Subarus = weak, unless they have a huge hot nasty wing..
        Can't wait for mine, trying to figure out which one it want though first..
          Trafik Jamz
          Subaru- decent wheels, sti wing, double din, tomei arms m7760 turbo w/ accompaning (sp?) mods.... etc
          I know a guy who has all those things 😉 Especially the STi wing. If you have a silver wrx wingless I'd contemplate a trade of the trunk lids.
          701.541.3484
          • BassplayerB Offline
            BassplayerB Offline
            Bassplayer
            I'm currently working on buying a 12.19" Wilwood Big Brake kit, so I guess that goes on the winter mod list for the CRX. :icon_bigsmurf:
            1995 GMC Sierra
              Isn't that overkill for a lil CRX
              • dubbsyD Offline
                dubbsyD Offline
                dude, endos!
                  BassplayerB Offline
                  Bassplayer
                  Yes :icon_rr: but it's not my DD. Having a 200hp motor in that car is overkill, and that's exactly what I'm going for haha Also I've just always had a place in my heart for pimp wheels with really nice brakes behind them.
                  Oh yeah and I just bought the brakes so they will be on their way Monday! There goes all my Christmas $.
                  1995 GMC Sierra
                    Bassplayer;297049 wrote:
                    Having a 200hp motor in that car is overkill, and that's exactly what I'm going for haha$.
                    yes... soooooo overkill
                      what size wheels will u have to run? 15's are about perfect imo.. anything bigger than 16's look just plain gay...
                      I think DA brakes with good pads/rotors will be good enough, if not i've seen ppl make prelude brakes fit... also a lot cheaper...
                        BassplayerB Offline
                        Bassplayer
                        zbrown;297054 wrote:
                        yes... soooooo overkill\
                        Ha yeah I didn't really mean that like literally. It's only ~8.5HP/lb, hopefully less than 6 with nitrous. I hope to be bringing this car to school with me in Ohio over Spring break, and racing it at Mid Ohio Speedway in the summer. It's not made to be a suppidly overpowered Honda, just cheap, fast, and reliable.
                        You have to run 16's on them. I'll be running 16X7 +35 Desmonds. I got a really really good deal on them that I couldn't pass up. Like I said I'm a sucker for good brakes, and these calipers also fit 11" rotors so I can always switch to those if I feel like running a 15" wheel.
                        1995 GMC Sierra
                        • XJHEADX Offline
                          XJHEADX Offline
                          XJHEAD;296351 wrote:
                          Will be doing the following;
                          Mini-tub to get some 315-60-15 Radial tires to fit.
                          Crank trigger for the ignition.
                          Would like to;
                          Possibly upgrade to DFI GEN VII fron GEN VII
                          Get rid of the two electric fuel pumps Weldon 2035 and the ACCEl pump and get a belt drive.
                          Drop fuel pressure from 60 psi to 43 psi and get rid of the 160 lbr's and put in some 225's
                          2-speed 400 or a glide
                          will add to the list later.
                          The mini-tub kit showed up and the tires are on order. Here is a picture of a 315 vs a 325, big difference.
                            I think you meant lb/hp. 🙂 Otherwise you are in top fuel dragster territory.
                              holy balls, what is the OD difference on those
                              edit saw it was only 2" difference, looks like more
                              • z31Z Offline
                                z31Z Offline
                                z31
                                How is this tire change going to be gearing wise?
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  It will be a like a 2.87 gear. If I want it to be the same I would have to get some 3.31 gears. I'll worry about a gear change later if needed. I think I'll be ok with what I am running. I need the extra gearing to be the first in the 180's anyways..:icon_rr:
                                  • z31Z Offline
                                    z31Z Offline
                                    z31
                                    Fidanza 11lb aluminum flywheel
                                    South Bend DXD stage 5 clutch
                                    Balance clutch and flywheel as an assembly
                                    Intercooler and piping install
                                    Blow off valve
                                    88t front rotors and twin pistion calipers (bigger)
                                    88t rear calipers and vented rotors (bigger)
                                    88t rear control arms :icon_bigsmurf:
                                    • 00Ws6TransAm0 Offline
                                      00Ws6TransAm
                                      Grr;296394 wrote:
                                      finish wiring, fuel system, finish my headers, get the turbo spinnin (oil lines) and then go destroy the rear axle so i can put a 8.8 in and 275 drag radials. Then it should pull the wheels...
                                      Regret abandoning your LS motor yet?:)
                                      Ill have to check your car out, still havent. WE may even have to line them up.
                                        Na i hear he misses the LT.....
                                          dont think i will ever miss a god damn lt, guess it was pretty good if you get past the electronics. I like my new setup its pretty bad ass
