  4. Car Updates / Progress
  5. Project Time Attack Miata
70 Posts 28 Posters 22.6k Views
  • wesholeW
    wesholeW
    Pretty sick.
    • zbrownZ
      zbrownZ
      I am going to hump that cage
      • bubbaB
        bubbaB
        that cage looks sick
        • SlowicaS
          SlowicaS
          Slowica
          That is sex
          • P
            P
            Aside from gussets and welding the cage fabrication is complete.
            • P
              P
              Rotors and wheel studs installed:
              New rotors vs stock:
              • B
                B
                nice Nick... get that thing ready to rock for Proving Grounds.
                • K
                  K
                  Do you have any parts of the cage that go forward past the firewall?
                  • P
                    P
                    Will have bars that are braced to the firewall but for the classes im looking to build for bars piercing the firewall are not allowed. that and there really is no front strut towers in a miata that sit almost flush atop the frame rails.
                    • capitljC
                      capitljC
                      capitlj
                      Those are a little bigger than stock eh?
                      Mitch Hedberg wrote:
                      2004 Impala LS 3.8
                      • SlowicaS
                        SlowicaS
                        Slowica
                        Needs more cage
                        • E
                          E
                          Eurofan
                          Track Car!! :icon_cheers:
                          Nice progress man!
                          • JoelJ
                            JoelJ
                            <is officially pumped for this car! after being in hiding for ... 10? years. since this will be a track car, are you removing the headlights? if so, when can I buy them from you!
                            • P
                              P
                              I'll see what i can do, time is of the essence here and i haven't had much to dedicate to this. Rear diff, brake calipers and brackets are ordered, possibly be here this week then that should wrap up the drivetrain until the trans grenades.
                              It'll possibly see some street time thus i'll be keeping it as much street legal as possible.
                              • DaveHD
                                DaveHD
                                Wow, is that whole cage made of 1-5/8"? If so, that car is safe enough for Spanky Spangler to take and go jump some bus's with.
                                • inspector01I
                                  inspector01I
                                  Looks amazing Nick, good work.
                                  What engine management are you running with it, and do you have a built motor already??
                                  • P
                                    P
                                    Yeah its all 1 5/8" thus far.
                                    AEM for EMS.
                                    Motor isnt built yet, right now trying to get all the chassis, suspension, driveline, and brakes complete and the car back as complete roller and go from there. Lots of work and lots of time that i currently dont have @ the moment.
                                    • P
                                      P
                                      Progress:
                                      -Torsen rear diff installed
                                      -SS brake lines, 1.8 calipers and adaptors brackets installed
                                      -Motor pulled, torn down and off to machine shop (10:1 Wiseco pistons, Eagle rods)
                                      • Gundar1G
                                        Gundar1G
                                        Gundar1
                                        What do you expect the final weight to be?
                                        EVO
                                        • P
                                          P
                                          Not a clue. If i remember correctly it weighed in the 2140lb range stock.
                                          Rear brake rotor, pads, and driveshaft showed up today. Had to pickup a new longblock as the last swap suffered fron thrust bearing failure which in turn salvaged that longblock. Dropped off the other motor a week ago, may possibly see it back this week, then start assembling this weekend if all goes as planned.
