  4. Car Updates / Progress
  5. Project Time Attack Miata
70 Posts 28 Posters 22.6k Views
  • P
    P
    KA-T_240;305318 wrote:
    Do you have any parts of the cage that go forward past the firewall?
    Will have bars that are braced to the firewall but for the classes im looking to build for bars piercing the firewall are not allowed. that and there really is no front strut towers in a miata that sit almost flush atop the frame rails.
    • capitljC
      capitljC
      capitlj
      Those are a little bigger than stock eh?
      Mitch Hedberg wrote:
      2004 Impala LS 3.8
      • SlowicaS
        SlowicaS
        Slowica
        Needs more cage
        • E
          E
          Eurofan
          Track Car!! :icon_cheers:
          Nice progress man!
          • JoelJ
            JoelJ
            <is officially pumped for this car! after being in hiding for ... 10? years. since this will be a track car, are you removing the headlights? if so, when can I buy them from you!
            • P
              P
              btleier;305307 wrote:
              nice Nick... get that thing ready to rock for Proving Grounds.
              I'll see what i can do, time is of the essence here and i haven't had much to dedicate to this. Rear diff, brake calipers and brackets are ordered, possibly be here this week then that should wrap up the drivetrain until the trans grenades.
              It'll possibly see some street time thus i'll be keeping it as much street legal as possible.
              • DaveHD
                DaveHD
                Wow, is that whole cage made of 1-5/8"? If so, that car is safe enough for Spanky Spangler to take and go jump some bus's with.
                • inspector01I
                  inspector01I
                  Looks amazing Nick, good work.
                  What engine management are you running with it, and do you have a built motor already??
                  • P
                    P
                    Yeah its all 1 5/8" thus far.
                    AEM for EMS.
                    Motor isnt built yet, right now trying to get all the chassis, suspension, driveline, and brakes complete and the car back as complete roller and go from there. Lots of work and lots of time that i currently dont have @ the moment.
                    • P
                      P
                      Progress:
                      -Torsen rear diff installed
                      -SS brake lines, 1.8 calipers and adaptors brackets installed
                      -Motor pulled, torn down and off to machine shop (10:1 Wiseco pistons, Eagle rods)
                      • Gundar1G
                        Gundar1G
                        Gundar1
                        What do you expect the final weight to be?
                        EVO
                        • P
                          P
                          Not a clue. If i remember correctly it weighed in the 2140lb range stock.
                          Rear brake rotor, pads, and driveshaft showed up today. Had to pickup a new longblock as the last swap suffered fron thrust bearing failure which in turn salvaged that longblock. Dropped off the other motor a week ago, may possibly see it back this week, then start assembling this weekend if all goes as planned.
                          • inspector01I
                            inspector01I
                            Get it done for BIR, shit load of testing time for pretty cheap...
                            • BookemB
                              BookemB
                              Bookem
                              Did you have 1.8 or 1.6? I still have one sitting around complete throttle body to clutch I'm looking to get rid of.
                              Legacy GT
                              Gmc Suburban
                              Hallorann: Fargostreet?
                              Hallorann: No, I ain't.
                              • P
                                P
                                If it was only that easy it'd have been done long time ago but we've been slammed w/ work this spring a top of the new development and testing little time is left come end of the day/week.
                                It's a 1.8
                                • P
                                  P
                                  Getting closer:
                                  • JoelJ
                                    JoelJ
                                    do you have the onl exhaust from this car by any chance? I am in need of one
                                    • Chance91C
                                      Chance91C
                                      Chance91
                                      Hate to tell you this, Nick, and you probably only know, but if you've got the original 5-speed you'll be very luck to last a single track day before it shreds its gears. I'd really look into a SE/LE 6-speed. The MSM unit is nice for its shot-peened gears, but I'm just unhappy as hell with mine. Really bad shifting attributed to an improperly designed shift gate, and syncro key retardation. I am going to use my old 6 to work on figuring that out. MER racing has syncro's/keys they designed to help fix the problem.
                                      Bob Bundy has managed to put down 350 something through a 6 without grenading it, however the 5 speed stories blowing up from 250ft lbs of tq on up are endless.
                                      • DelSlowD
                                        DelSlowD
                                        Miata Guru.
                                        • P
                                          P
                                          I am well aware of the 5 spd trans issues and honestly dont really care if it blows up, its an easy swap and the clutch will need to be replaced once i turn the boost up anyway.
                                          Sounds like you've been doing a little to much forum reading... I like to do things from experience not from reading and will approach the issue once its in front of me.
