  4. Car Updates / Progress
  5. Project Time Attack Miata
70 Posts 28 Posters 22.1k Views
    DaveH;305382 wrote:
    Wow, is that whole cage made of 1-5/8"? If so, that car is safe enough for Spanky Spangler to take and go jump some bus's with.
    Yeah its all 1 5/8" thus far.
    inspector01;305396 wrote:
    Looks amazing Nick, good work.
    What engine management are you running with it, and do you have a built motor already??
    AEM for EMS.
    Motor isnt built yet, right now trying to get all the chassis, suspension, driveline, and brakes complete and the car back as complete roller and go from there. Lots of work and lots of time that i currently dont have @ the moment.
      Progress:
      -Torsen rear diff installed
      -SS brake lines, 1.8 calipers and adaptors brackets installed
      -Motor pulled, torn down and off to machine shop (10:1 Wiseco pistons, Eagle rods)
      • Gundar1G Offline
        Gundar1G Offline
        Gundar1
        What do you expect the final weight to be?
        EVO
          Not a clue. If i remember correctly it weighed in the 2140lb range stock.
          Rear brake rotor, pads, and driveshaft showed up today. Had to pickup a new longblock as the last swap suffered fron thrust bearing failure which in turn salvaged that longblock. Dropped off the other motor a week ago, may possibly see it back this week, then start assembling this weekend if all goes as planned.
            Get it done for BIR, shit load of testing time for pretty cheap...
            • BookemB Offline
              BookemB Offline
              Bookem
              Did you have 1.8 or 1.6? I still have one sitting around complete throttle body to clutch I'm looking to get rid of.
              Legacy GT
              Gmc Suburban
              Hallorann: Fargostreet?
              Hallorann: No, I ain't.
                If it was only that easy it'd have been done long time ago but we've been slammed w/ work this spring a top of the new development and testing little time is left come end of the day/week.
                It's a 1.8
                  Getting closer:
                    do you have the onl exhaust from this car by any chance? I am in need of one
                    • Chance91C Offline
                      Chance91C Offline
                      Chance91
                      Hate to tell you this, Nick, and you probably only know, but if you've got the original 5-speed you'll be very luck to last a single track day before it shreds its gears. I'd really look into a SE/LE 6-speed. The MSM unit is nice for its shot-peened gears, but I'm just unhappy as hell with mine. Really bad shifting attributed to an improperly designed shift gate, and syncro key retardation. I am going to use my old 6 to work on figuring that out. MER racing has syncro's/keys they designed to help fix the problem.
                      Bob Bundy has managed to put down 350 something through a 6 without grenading it, however the 5 speed stories blowing up from 250ft lbs of tq on up are endless.
                        Miata Guru.
                          I am well aware of the 5 spd trans issues and honestly dont really care if it blows up, its an easy swap and the clutch will need to be replaced once i turn the boost up anyway.
                          Sounds like you've been doing a little to much forum reading... I like to do things from experience not from reading and will approach the issue once its in front of me.
                          • Chance91C Offline
                            Chance91C Offline
                            Chance91
                            Eh, if you say so. I've not blown up my own 5 speed yet, but I've been at a few track events where its happened. You're right though, at least its an easy enough swap.
                            I'm not a heavy track guy though, I'm hoping to get deeper into the sport in the next year. Been to a lot of tracks and events, but I've only run a handful myself.
                            Anyway, I love the project, wish you luck on it.
                              I dont.
                                  Great #'s Nick!!!
                                    nice!
                                    wish it was layed over RPM instead of MPH so you could see how it spools
                                    • BookemB Offline
                                      BookemB Offline
                                      Bookem
                                      zbrown;314373 wrote:
                                      nice!
                                      I'm glad you pointed that out, I was wondering......
                                      Legacy GT
                                      Gmc Suburban
                                      • 91nbtsi9 Offline
                                        91nbtsi9 Offline
                                        Holy, nice!
                                          Great numbers!
