  4. Car Updates / Progress
  5. Project Time Attack Miata
70 Posts 28 Posters 22.6k Views
  • P
    P
    Getting closer:
    • JoelJ
      JoelJ
      do you have the onl exhaust from this car by any chance? I am in need of one
      • Chance91C
        Chance91C
        Chance91
        Hate to tell you this, Nick, and you probably only know, but if you've got the original 5-speed you'll be very luck to last a single track day before it shreds its gears. I'd really look into a SE/LE 6-speed. The MSM unit is nice for its shot-peened gears, but I'm just unhappy as hell with mine. Really bad shifting attributed to an improperly designed shift gate, and syncro key retardation. I am going to use my old 6 to work on figuring that out. MER racing has syncro's/keys they designed to help fix the problem.
        Bob Bundy has managed to put down 350 something through a 6 without grenading it, however the 5 speed stories blowing up from 250ft lbs of tq on up are endless.
        • DelSlowD
          DelSlowD
          Miata Guru.
          • P
            P
            I am well aware of the 5 spd trans issues and honestly dont really care if it blows up, its an easy swap and the clutch will need to be replaced once i turn the boost up anyway.
            Sounds like you've been doing a little to much forum reading... I like to do things from experience not from reading and will approach the issue once its in front of me.
            • Chance91C
              Chance91C
              Chance91
              Eh, if you say so. I've not blown up my own 5 speed yet, but I've been at a few track events where its happened. You're right though, at least its an easy enough swap.
              I'm not a heavy track guy though, I'm hoping to get deeper into the sport in the next year. Been to a lot of tracks and events, but I've only run a handful myself.
              Anyway, I love the project, wish you luck on it.
              • P
                P
                I dont.
                • P
                  P
                  • wesholeW
                    wesholeW
                    Great #'s Nick!!!
                    • zbrownZ
                      zbrownZ
                      nice!
                      wish it was layed over RPM instead of MPH so you could see how it spools
                      • BookemB
                        BookemB
                        Bookem
                        zbrown;314373 wrote:
                        nice!
                        I'm glad you pointed that out, I was wondering......
                        Legacy GT
                        Gmc Suburban
                        Hallorann: Fargostreet?
                        Hallorann: No, I ain't.
                        • 91nbtsi9
                          91nbtsi9
                          Holy, nice!
                          • SPANISH-RICES
                            SPANISH-RICES
                            Great numbers!
                            • fdfreakF
                              fdfreakF
                              fdfreak
                              very nice. I saw you driving it around last night. I was in the blue fd next to you on main.
                              12.645@118mph 12.6psi
                              • zbrownZ
                                zbrownZ
                                hey what did this do today?!?
                                this thing is pimp, hope it ran well granted it isn't setup for drag
                                • JoelJ
                                  JoelJ
                                  I rolled out there for a little while. People were saying 11.6.
                                  • wesholeW
                                    wesholeW
                                    11.3 with alien driving.
                                    • bubbaB
                                      bubbaB
                                      definitely some nice passes this weekend..
                                      • P
                                        P
                                        11.34, 11.44 and 11.52 were the 3 best ET's. The trans will not shift @ high rpm into 3rd gear and i've had 2 trans do the same thing so currently one is tore apart on the bench to see what may be the root of the issue. At high rpm it either goes into 3rd gear and free revs as if the gear is non existant or it goes into the 3rd gear gate but somehow manages to use the 5th gear. You can pull it back out and reput it into 3rd gear and its fine, turns out it'll run 11.5-11.60's all day doing such... Short shifting 3rd around 6k rpm kevin netted the 11.34.
                                        • bubbaB
                                          bubbaB
                                          what were u running for 60ft? that thing ripped outa the hole on slicks...
