  4. Tang Band 8" subwoofer in box
42 Posts 14 Posters 2.2k Views
    Trafik Jamz
    The W8-740 is one of the highest excursion 8" subwoofers available on the market. It utilizes a heavy-duty paper cone, foam surround, and bumped back plate for maximum mechanical movement. The 2" 4-layer voice coil, vented pole piece, and heavy-duty aluminum voice coil former provide impressive power handling. Excellent for small-enclosure home or automotive subwoofers. Specifications: *Power Handling: 150 watts RMS/300 watts max *VCdia: 2" *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 28-1,000 Hz *Fs: 28 Hz *SPL: 84 dB 2.83V/1m *Vas: 0.81 cu. ft. *Qms: 10.53 *Qes: .30 *Qts: .30 *Xmax: 12mm *Dimensions: Overall diameter 8-1/4", Cutout diameter 7-1/4", Depth 4-3/4"
    701.541.3484
      blackcherryTSi;308707 wrote:
      ive got a cheap V3 400 watt amp on mine and it hits pretty damn good. i wanna step up to 500-600 tho see what it has ha
      I know where there's an amp that size, just sitting around too 🙂
      bump for some sweet bumps...
        wishinsky;308713 wrote:
        Well wes if you have any of these left maybe i will look into one in about a month if you still go it. I can't fit my 15" in the trunk so it needs to go.
        Rebuild the box for the car?? It's not that difficult...
          Well, three down..... 1 to go. Thanks for your business Faber.
            Trafik Jamz
            The sub box he needs is about 4 cuft+ port volume....so around 5.2 cuft total....that's why it won't fit.
            701.541.3484
              Oh and btw..... I have sold to two of the 3 cheapest, tightest mutherfuckers that frequent this site. Brandon and Faber...............
              TORBS!!!!! your next.
                HA epic!!
                  lmao, what about poly fill? Doesn't that "spoof" more enclosure space? Hell, just build the trunk into a huge box hahah jk
                    Trafik Jamz
                    It won't compensate for too small of a box, but it will make appropriate sized enclosures act like a slightly larger enclosure by slowing down the rear waves....and even then would only really make it sound like ~.2 cuft bigger
                    701.541.3484
                    • gsrEKG Offline
                      gsrEKG Offline
                      gsrEK
                      i got dibs on one today
                      2009 Yamaha Zuma 125, gas HOG
                      2008 Honda Fit daily
                      A s2k
                      1991 Honda civic DX Mint SOLD
                      1988 Mitsubishi Mighty max
                      > BlackEJ8;233529 wrote:
                        Ya travis gets the last one
                          If theres enough interest, I may be able to work out a deal with Chuck on some Atomic subs and build some more. the price may be a little bit higher but I dont think much more.
                          The amount of interest will gauge how far I will take it. Holla at ya boy if ya want something.
                          • dont got a rideD Offline
                            dont got a ride
                            did you have one bumping on saturday? i could hear it clear across the parkin lot
                            2001 2.5rs (project RSTI)
                              Ya. msg length.
                                so did travis buy it? if not i'll take it.
                                • gsrEKG Offline
                                  gsrEKG Offline
                                  gsrEK
                                  sure did
                                  A s2k
                                    Ya Joel, he did. You shoulda bought the first one 2-3 weeks ago when you had first chance. Sorry.
                                      its cool. just curious, not gonna lose sleep over it.
                                      • F Offline
                                        F Offline
                                        fanaticrockford
                                        Can chuck get Tang Band or just have Atomic build an identical speaker?
                                        Also the ones you sold were a W8-740C. I can only find a W8-740P. Are they the same sub with a new part #?
                                          Identical in ALL parameters except power handling. The c's were rated at a lil less total power. Chuck can get both the Tang Bands and the Atomics. By the looks of them, I'd be tempted to do the Atomics. See what Chuck can do for you.
