  4. Tang Band 8" subwoofer in box
42 Posts 14 Posters 2.2k Views
    Oh and btw..... I have sold to two of the 3 cheapest, tightest mutherfuckers that frequent this site. Brandon and Faber...............
    TORBS!!!!! your next.
      HA epic!!
        Trafik Jamz;308783 wrote:
        The sub box he needs is about 4 cuft+ port volume....so around 5.2 cuft total....that's why it won't fit.
        lmao, what about poly fill? Doesn't that "spoof" more enclosure space? Hell, just build the trunk into a huge box hahah jk
          Trafik Jamz
          It won't compensate for too small of a box, but it will make appropriate sized enclosures act like a slightly larger enclosure by slowing down the rear waves....and even then would only really make it sound like ~.2 cuft bigger
          701.541.3484
          • gsrEKG Offline
            gsrEKG Offline
            gsrEK
            i got dibs on one today
            2009 Yamaha Zuma 125, gas HOG
            2008 Honda Fit daily
            A s2k
            1991 Honda civic DX Mint SOLD
            1988 Mitsubishi Mighty max
            > BlackEJ8;233529 wrote:
              Ya travis gets the last one
                If theres enough interest, I may be able to work out a deal with Chuck on some Atomic subs and build some more. the price may be a little bit higher but I dont think much more.
                The amount of interest will gauge how far I will take it. Holla at ya boy if ya want something.
                • dont got a rideD Offline
                  dont got a ride
                  did you have one bumping on saturday? i could hear it clear across the parkin lot
                  2001 2.5rs (project RSTI)
                    Ya. msg length.
                      so did travis buy it? if not i'll take it.
                      • gsrEKG Offline
                        gsrEKG Offline
                        gsrEK
                        sure did
                        A s2k
                          Ya Joel, he did. You shoulda bought the first one 2-3 weeks ago when you had first chance. Sorry.
                            its cool. just curious, not gonna lose sleep over it.
                            • F Offline
                              F Offline
                              fanaticrockford
                              Can chuck get Tang Band or just have Atomic build an identical speaker?
                              Also the ones you sold were a W8-740C. I can only find a W8-740P. Are they the same sub with a new part #?
                                Identical in ALL parameters except power handling. The c's were rated at a lil less total power. Chuck can get both the Tang Bands and the Atomics. By the looks of them, I'd be tempted to do the Atomics. See what Chuck can do for you.
                                  Trafik Jamz
                                  If you do an Atomic MA series the output would be the same, but the box size would be about 1/2 of what the Tangband requires.
                                  I have 6 of the MA-8's going into a 2.0 cubic foot vented enclosure.
                                  701.541.3484
                                    HMMMMMMM 1/2 The the box size? That sounds pretty sweet. I might be intersted in that.
                                    • BookemB Offline
                                      BookemB Offline
                                      Bookem
                                      What kind of weight would the ma's be, two of them in sepereate boxes? Would 1/2" be enough or should the box be 3/4"?
                                      Legacy GT
                                      Gmc Suburban
                                      Hallorann: Fargostreet?
                                      Hallorann: No, I ain't.
                                        Trafik Jamz
                                        I'd say 5/8" would be the minimum you'd want to use in any circumstance...Unless you are bracing the crap out of the box and putting fiberglass resin on the inside of the box to make it a bit more rigid.
                                        Shooting from the hip on weight (based on memory) each one weighs about 8 to 10 lbs. I'd say that if you have a pair of them, in a box of about 1 cuft total (including port volume) would weigh ~35-40 lbs...maybe less.
                                        701.541.3484
                                          Just so EVERYONE knows. These were a AWESOME DEAL. The package price I have sold these at will NOT be what its going to cost for a different set up.<u> I sold these for what I had into them.</u> If I have to build new enclosures, I wont do it for free. It will cost more. How much really depends.
