  4. Tang Band 8" subwoofer in box
42 Posts 14 Posters 1.9k Views
    Trafik Jamz
    PSiedTSi;308724 wrote:
    Rebuild the box for the car?? It's not that difficult...
    The sub box he needs is about 4 cuft+ port volume....so around 5.2 cuft total....that's why it won't fit.
    701.541.3484
      Oh and btw..... I have sold to two of the 3 cheapest, tightest mutherfuckers that frequent this site. Brandon and Faber...............
      TORBS!!!!! your next.
        HA epic!!
          lmao, what about poly fill? Doesn't that "spoof" more enclosure space? Hell, just build the trunk into a huge box hahah jk
            Trafik Jamz
            It won't compensate for too small of a box, but it will make appropriate sized enclosures act like a slightly larger enclosure by slowing down the rear waves....and even then would only really make it sound like ~.2 cuft bigger
            701.541.3484
            • gsrEKG Offline
              gsrEKG Offline
              gsrEK
              i got dibs on one today
              2009 Yamaha Zuma 125, gas HOG
              2008 Honda Fit daily
              A s2k
              1991 Honda civic DX Mint SOLD
              1988 Mitsubishi Mighty max
              > BlackEJ8;233529 wrote:
                Ya travis gets the last one
                  If theres enough interest, I may be able to work out a deal with Chuck on some Atomic subs and build some more. the price may be a little bit higher but I dont think much more.
                  The amount of interest will gauge how far I will take it. Holla at ya boy if ya want something.
                  • dont got a rideD Offline
                    dont got a ride
                    did you have one bumping on saturday? i could hear it clear across the parkin lot
                    2001 2.5rs (project RSTI)
                      Ya. msg length.
                        so did travis buy it? if not i'll take it.
                        • gsrEKG Offline
                          gsrEKG Offline
                          gsrEK
                          sure did
                          A s2k
                            Ya Joel, he did. You shoulda bought the first one 2-3 weeks ago when you had first chance. Sorry.
                              its cool. just curious, not gonna lose sleep over it.
                              • F Offline
                                F Offline
                                fanaticrockford
                                Can chuck get Tang Band or just have Atomic build an identical speaker?
                                Also the ones you sold were a W8-740C. I can only find a W8-740P. Are they the same sub with a new part #?
                                  Identical in ALL parameters except power handling. The c's were rated at a lil less total power. Chuck can get both the Tang Bands and the Atomics. By the looks of them, I'd be tempted to do the Atomics. See what Chuck can do for you.
                                    Trafik Jamz
                                    If you do an Atomic MA series the output would be the same, but the box size would be about 1/2 of what the Tangband requires.
                                    I have 6 of the MA-8's going into a 2.0 cubic foot vented enclosure.
                                    701.541.3484
                                      HMMMMMMM 1/2 The the box size? That sounds pretty sweet. I might be intersted in that.
                                      • BookemB Offline
                                        BookemB Offline
                                        Bookem
                                        What kind of weight would the ma's be, two of them in sepereate boxes? Would 1/2" be enough or should the box be 3/4"?
                                        Legacy GT
                                        Gmc Suburban
                                        Hallorann: Fargostreet?
                                        Hallorann: No, I ain't.
                                          Trafik Jamz
                                          I'd say 5/8" would be the minimum you'd want to use in any circumstance...Unless you are bracing the crap out of the box and putting fiberglass resin on the inside of the box to make it a bit more rigid.
                                          Shooting from the hip on weight (based on memory) each one weighs about 8 to 10 lbs. I'd say that if you have a pair of them, in a box of about 1 cuft total (including port volume) would weigh ~35-40 lbs...maybe less.
                                          701.541.3484
