  4. Shop?
Shop?
9 Posts 7 Posters 1.0k Views
  • N Offline
    N Offline
    NDSUEm2
    I have a '65 mustang with a 4.7 L 289 that is having some issues. Meaning, it completely lost its balls. I have taken it to at least 3 different mechanics in fargo and it has not gotten any better. Ford helped a little bit, but I still have trouble getting to 65MPH or breaking the rear end loose at all.
    Does anyone know a good place to take it who would know about classic V8s? It isn't really that modified, just has a new cooling system, headers, shelby style side exit exhaust, an edelbrock hi-rise intake manifold, and a holley 650 carb, if that helps at all. I'm kind of sick of not being able to drive it how I want to.
    • BookemB Offline
      BookemB Offline
      Bookem
      Any carb work lately, what fuel are you using, adjusted valves, points distributor?
      Legacy GT
      Gmc Suburban
      Hallorann: Fargostreet?
      Hallorann: No, I ain't.
      • N Offline
        N Offline
        NDSUEm2
        not using points, I am not sure about the carb work because it has been in and out of shops, but I kind of doubt it. The carb works well enough to drive it and that's about it. I also doubt that the valves have been adjusted, but I don't have any idea. I'm just running 87 pump gas and running seafoam through it every once in a while.
        Other problems that came to mind- mild leak between the water pump and thermostat and the black. I also usually go through at least one starter solenoid a summer.
        • ruthless351R Offline
          ruthless351
          I've played with some carbed mustangs before. Dont you think a 650 is kinda big for that set up?
          • C Offline
            C Offline
            CivicEX7777777
            Talk to Mike (Wa2fastcamaro), i think thats his screen name still. Hes good with old v8's maybe he can help you out.
            2007 Pontiac G5
            2007 Yamaha C3
            2002 Oldsmobile Alero
            1994 Nissan Sentra
            • Bp-08B Offline
              Bp-08B Offline
              Bp-08
              NDSUEm2;309372 wrote:
              I have a '65 mustang with a** 4.7 L 289** that is having some issues. Meaning, it completely lost its balls. I have taken it to at least 3 different mechanics in fargo and it has not gotten any better. Ford helped a little bit, but I still have trouble getting to 65MPH or breaking the rear end loose at all.
              Thats your problem, but really I think your running her a little rich.
              • N Offline
                N Offline
                NDSUEm2
                I know it's a small engine, but it has gotten significantly worse. I just wanted it back to normal.
                And yes. I am sure that the 650 is a bit big. But that was what I installed when I was 16, so that is what I have to work with.
                Ruthless351, If you have the time, I would greatly appreciate if you took a look at it. If that is the problem, tuning would save me a lot of money and time. Or if you know a place to take it to get tuned, that would work as well.
                  Check the compression and turn down the fuel a little bit
                    If its still intact (all original) internally, theres a good chance that the unleaded low octane fuel has done a number on your valve seats. They are soft and get beat to shit with the hot temps todays low octane creates in your combustion chamber. That "could" explain the loss of power over time. Worn camshaft could as well. It would be interesting to see your set up to determine your issue.
