MAP BIR race
zbrown;312740 wrote:
1/8 trap is impressive for suredid you get the boot eventually then?
nice times, how much boost where you on then ~25?
I think its at 30psi, Yes I got the boot!
Congrats Kevin
thanks guys
Good job, congrats on getting there, car looked good.
zbrown;312813 wrote:
yeah slicks would make a difference! would you have to worry about breaking anything launching hard on them?Kevin, what does a car like yours weigh with you in it? 3300?
I think slicks would get me some 1.5 60 foots. That would bring me down to 10.2's ish Ive alreayd broke a t-case from wheel hopping and have upgraded the diff.
I think it weighs 3150 w me.....I will be trying for 10.5 or better at the next tintmaster race.. But im sure the traction will be worse.. I have falkin 615's at 17psi.. Is there a trick to make them stickier?
That 10.6 run was on 32 psi. Nate you should check out evolutionm.net
yeah slicks would drop you big time
what i don't get is how come you are only pulling ~25mph the big end
i would expect your 1/4 trap to be around 140 going off your 1/8
is that what AWD or the evo gearing does??
ha, and i am not ripping, just curious why that is
zbrown;312825 wrote:
yeah slicks would drop you big timewhat i don't get is how come you are only pulling ~25mph the big end
I would need to check my logs to see if the ecu was pulling timing or picking up knock.. The car should pick up 30 on the top end..
