  3. Track Talk
  4. MAP BIR race
MAP BIR race
24 Posts 13 Posters 4.3k Views
    Congrats Kevin! It was good to see the car running so good.
      aliengotpsi
      zbrown;312740 wrote:
      1/8 trap is impressive for sure
      did you get the boot eventually then?
      nice times, how much boost where you on then ~25?
      I think its at 30psi, Yes I got the boot!
      Kevin Smith
      Straightlinedetailing.com
      • FG2F Offline
        FG2F Offline
        FG2
        Congrats on a great build Kevin! Shane @ DB always goes the extra mile. Highly recommended!
          congrats Kevin....
            Congrats Kevin
              aliengotpsi
              thanks guys
              Kevin Smith
                ha atleast they waited till you got it done
                no vids? someone has to have some vids
                • 91nbtsi9 Offline
                  91nbtsi9 Offline
                  Nicely done, Alien! Wish I would have been there to see this.
                    Good job, congrats on getting there, car looked good.
                      aliengotpsi
                      [ame]http://www.youtube.com/watch?v=ezPoHNwVqMQ[/ame]
                      Kevin Smith
                        yeah slicks would make a difference! would you have to worry about breaking anything launching hard on them?
                        Kevin, what does a car like yours weigh with you in it? 3300?
                          aliengotpsi
                          I think slicks would get me some 1.5 60 foots. That would bring me down to 10.2's ish Ive alreayd broke a t-case from wheel hopping and have upgraded the diff.
                          I think it weighs 3150 w me.....I will be trying for 10.5 or better at the next tintmaster race.. But im sure the traction will be worse.. I have falkin 615's at 17psi.. Is there a trick to make them stickier?
                          Kevin Smith
                          • 91nbtsi9 Offline
                            91nbtsi9 Offline
                            That makes me want to get another car...bad.
                              aliengotpsi
                              That 10.6 run was on 32 psi. Nate you should check out evolutionm.net
                              Kevin Smith
                              • 2wheeler2 Offline
                                2wheeler2 Offline
                                2wheeler
                                Shoulda weighed at BIR. The scale was open.
                                '08 Suzuki Hayabusa
                                '09 Yamaha Zuma 200cc
                                '95 E-350 7.5L
                                  yeah slicks would drop you big time
                                  what i don't get is how come you are only pulling ~25mph the big end
                                  i would expect your 1/4 trap to be around 140 going off your 1/8
                                  is that what AWD or the evo gearing does??
                                  ha, and i am not ripping, just curious why that is 🙂
                                    aliengotpsi
                                    I would need to check my logs to see if the ecu was pulling timing or picking up knock.. The car should pick up 30 on the top end..
                                    Kevin Smith
                                      yeah being a bigger power turbo car i would think it would pull ~35.... that is why i was curious if that was just a AWD thing or what
                                      regardless 130+ is moving good
