LOL craigslist ad...
thrash;317271 wrote:
How much torque do you think an F1 engine makes?For simplicity's sake, lets assume that in an F1 engine under 2010 rules makes about 750bhp at its rules-limited redline of 18,000 rpm, and that peak torque happens at peak power. (in reality, i beleive that peak torque would be a bit lower in the rpm band)
HP = Torque * RPM / 5252
Torque = HP * 5252 / RPM
torque = 750 * 5252 / 18000= 218 ft/lbs
Even under the earlier rules where the formula was 3 liter V10s, unlimited on revs, and they were pushing 1000hp, there was still under 300 ft/lbs of peak torque.
are you really comparing a f1 car to a honda civic? WOW!
I guess nobody ever bothered to think about most of the older rotary engines, and even the newer NA ones. The current RX8 is only rated at 159 ft/lb.
Unless I misremember, plenty of race-tuned S2000s are/were less than 200 ft/lb of torque.What about how light F1 cars are? The minimum race weight is 620kg (1367lb). How fast is a stock S2000/RX8/etc? How fast would it be with half the weight and less wind resistance? Science rules.
