  4. S2k swap
S2k swap
18 Posts 8 Posters 1.9k Views
  • 95_gsr_swap9 Offline
    95_gsr_swap
    Ok, I'm just gonna throw this out there and see what i get i guess.... I'm gonna be doing an s2k swap to a 86 corolla and im debating on weather or not i just wanna use all s2k harnesses or splice in for the cluster and use the 86 corolla body harness so what ever you have to say say it any advice or ideas will help.....
    92 Honda Civic VX 1.5l vtec-e - SOLD
    86 Toyota Corolla - Project
    B18C1 Boost Project Soon To Be Done Once Home - SOLD
    92 civic coupe b18b swap
    • gsrEKG Offline
      gsrEKG Offline
      gsrEK
      buy an s2000
      2009 Yamaha Zuma 125, gas HOG
      2008 Honda Fit daily
      A s2k
      1991 Honda civic DX Mint SOLD
      1988 Mitsubishi Mighty max
        95_gsr_swap
        lol would be nice but this should be fun when its done
          I would use the S2k motor harness for sure, splice into the factory harness when necessary. It's an 86, whats in it, 8 wires?
            Didn't I read somewhere that the S2000 engine actually rotates in the opposite direction as the Toyota engine it would be replacing and as a result, the corresponding rear diff is designed for that and would need to be utilized? If that is the case, You may run into an issue actually driving it without problems.
            This is just what I remember hearing. I have no clue personally. Just thought I'd throw that out there.
              95_gsr_swap
              you know wes thats a good thought ill do some research on it tomorrow and let you know what i find but thanks for the heads up
                95_gsr_swap
                Wes, as for the rear end it kept me up most of the night looking and from what i've found the stock rear end works perfectly but needs to be slightly upgraded do to the stock power differences in the engines
                  95_gsr_swap
                  from what i have found there should be 6 grounds and about 12 power wire left when all said and done, so your pretty frigin close lol
                    Hmm. So youre going to use the s2000 transmission ? Id use as much of the factory wiring as possible. Its be interesting to see where the shifter ends up in the corolla chassis. Good luck, itll be sweet if it gets finished.
                      95_gsr_swap
                      you have to cut back bout 2 or 3 inches and then you have the choice of shortening the e-brake handle or relocating it but from what I've seen its a pretty straight forward swap the wiring is the only thing I'm truly worried bout haven't found an exact diagram or example yet
                      http://img.photobucket.com/albums/v233/sportcarae/s2000%20swap%20pics/P1017398.jpg
                      http://img.photobucket.com/albums/v233/sportcarae/s2000%20swap%20pics/P1017481.jpg
                        95_gsr_swap
                        my other big concern is the spacer that i need to put between the frame and the lower crossmember and how it will affect the alignment and driveabilty of the car
                        picture is for reference
                        http://img.photobucket.com/albums/v233/sportcarae/s2000%20swap%20pics/P1017510.jpg
                        http://img.photobucket.com/albums/v233/sportcarae/s2000%20swap%20pics/P1017511.jpg
                        • GarageAlchemistG Offline
                          GarageAlchemist
                          make sure you mount it as low and as far back as you can get it. It will prolly drive like a go cart. I'm pretty sure Josh from fergus was going to do this swap, i'm sure he can give you the in's and out's of it, but i don't know what he is up to these days 1990tsi on here i believe...
                          97 GTi, 03 KJ
                            95_gsr_swap
                            ya that was his plan and i dont know what happened to it but its in my hands now and i will get it done. he still has a butt load of the parts with him in fergus but i cant seem to get ahold of him so a road trip might be in order
                              Lol
                              Standalone with a fresh flying lead harness.....cake and look factory
                                95_gsr_swap
                                zbrown;322192 wrote:
                                Lol
                                would be nice i just don't like the price tag of the stand alone and from what i've found the harness is supposed to be pretty simple to do i guess that you basically use a stripped s2k dash harness, full engine harness and bits from the corolla
                                  this isn't exactly a new swap idea... it's been done plenty of times and there should be write ups somewhere online
                                    95_gsr_swap
                                    this i know bubba, but all the write ups leave out alot of important info and leaves me looking for that info but in time i will have every thing i need to know plan is to start on the dash and wiring tomorrow
                                      I talk to josh all the time. PM me for contact info.
