  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • kylushK
    kylushK
    kylush
    This vid is far more entertaining... http://www.youtube.com/watch?v=NoKdNe_kIPM&feature=related haha jk man car sounds MEAN!!
    1998 Z28 Camaro
    • SPANISH-RICES
      SPANISH-RICES
      hahaha omg epic. such a sick car, great work !
      • C
        C
        Chirp5957
        zbrown;323487 wrote:
        made a bar mount for my camera, needs to be a little higher and not go into direct sunlight, but i made a test vid and it is sort of funny
        that is high gear on 13psi, i open the cutout right before
        http://www.youtube.com/watch?v=YkUgNzOpB2A
        :eek: sick dude.
        1996 cobra 13.20 @106
        4.10 gears
        short throw shift
        off road x pipe
        BBK Cold Air
        Diablo chip
        BBK LT
        • zbrownZ
          zbrownZ
          thanks guys!
          doh:icon_silent: haha
          • zbrownZ
            zbrownZ
            so... made my own camera mount. It means serious business, lol
            I crease the 1/4 panel before that cup comes off
            made a test vid, turned out rather cool i thought, only would be better with something beside me
            13psi, great highway surface, MT DRs
            FYI, anytime it is giving the loud hiss is when i am WOT, So you can tell when i am getting in and out of it on the first hit
            I open the cutout when i get into the car, camera is right beside the fuel pump as to why you can hear it so much
            first is a hit off idle from a stop...... shows spool and the nature of the converter and glide...... remember this is a 1.76 low gear with a 3.23 rear gear and tight converter
            second hit it is for a burst in high gear
            last is a hit from 45 in low gear and through high..... hooks
            turbo V8 rx7
            • GarageAlchemistG
              GarageAlchemistG
              GarageAlchemist
              haha, you still drive like shit. all you hear at idle is fuel pump(s)
              97 GTi, 03 KJ
              • zbrownZ
                zbrownZ
                Maybe since the camera is about 4" from an external pump??
                I may be a horsepoo driver but bring that 600 down and we will see if my bad driving will save you
                • GarageAlchemistG
                  GarageAlchemistG
                  GarageAlchemist
                  haha, we can do it up. but after you win i want a ride.
                  97 GTi, 03 KJ
                  • zbrownZ
                    zbrownZ
                    Mmmmmmk found out why the car leaned out in Fargo
                    out of injector
                    at my home elevation on 12psi i see a duty cycle of 85
                    at 14psi i see 98-100
                    (remember my current injectors are stable and linear up to 95%)
                    so that is why with the elevation drop and 14.5psi i was over the top and leaned out at Fargo
                    so it made me feel good to find out what was up
                    static is 43psi right now, not sure if i will bump the static or get the ID2000s
                    • zbrownZ
                      zbrownZ
                      bought a gopro, made some vids today..... fucking jews make you buy the add on screen. retarded
                      yes on the second vid no screen so i had no idea where the fuck it was pointed :poke:
                      weird from the first vid how you can tell the car drops the passenger rear on gas
                      My Great Movie 3
                      road3
                      • zbrownZ
                        zbrownZ
                        ready for sky diving
                        • zbrownZ
                          zbrownZ
                          here is my chute mount/class 3 hitch, haha
                          turned out well
                          think i will add some sort of eyelet on the inner shaft so that i can hook a ratchet strap on each side when the car is on the trailer. it would make life super simple
                          • 63vette6
                            63vette6
                            63vette
                            Looks pretty heavy. 😞
                            You need to start looking where you can lose 150 lbs to get that 8.
                            • PSiedTSiP
                              PSiedTSiP
                              Zac, weren't you running really low boost on your 9.20 pass? Or am I mistaken?
                              spanish-rice;237125 wrote:
                              • zbrownZ
                                zbrownZ
                                you are supposed to have a gameplan for me so i can get a 1.30 60ft out of it, haha
                                yeah 12-12.5psi, much more than that at Fargo's elevation i am out of injector though. Ill try bumping my bumping my fuel pressure up and see if the pump can handle it. If i can get it up to ~15psi that should get it done
                                so when is the 240 going to be under boost?
                                • PSiedTSiP
                                  PSiedTSiP
                                  Get some more injector, newb. Just got my 950's in the other day.
                                  As soon as the manifold is done. 🙂
                                  • zbrownZ
                                    zbrownZ
                                    I already have 1000s, lol
                                    big high Z injectors are $$$$, and a converter to low Z can suck my wee wee
                                    • PSiedTSiP
                                      PSiedTSiP
                                      Oh you nanner. Go buy some ID2000s and run your 8 ;).
                                      • zbrownZ
                                        zbrownZ
                                        Lol, the wife would notice that one
                                        all done
                                        car has about an inch of dust on it...needs to be driven
                                        • integra_gsr98I
                                          integra_gsr98I
                                          Did you finish the front half of the cage yet?
