  4. New Stuff
New Stuff
461 Posts 56 Posters 74.8k Views
    so... made my own camera mount. It means serious business, lol
    I crease the 1/4 panel before that cup comes off
    made a test vid, turned out rather cool i thought, only would be better with something beside me
    13psi, great highway surface, MT DRs
    FYI, anytime it is giving the loud hiss is when i am WOT, So you can tell when i am getting in and out of it on the first hit
    I open the cutout when i get into the car, camera is right beside the fuel pump as to why you can hear it so much
    first is a hit off idle from a stop...... shows spool and the nature of the converter and glide...... remember this is a 1.76 low gear with a 3.23 rear gear and tight converter
    second hit it is for a burst in high gear
    last is a hit from 45 in low gear and through high..... hooks
    turbo V8 rx7
    • GarageAlchemistG Offline
      GarageAlchemist
      haha, you still drive like shit. all you hear at idle is fuel pump(s)
      97 GTi, 03 KJ
        Maybe since the camera is about 4" from an external pump??
        I may be a horsepoo driver but bring that 600 down and we will see if my bad driving will save you
          GarageAlchemist
          haha, we can do it up. but after you win i want a ride.
          97 GTi, 03 KJ
            Mmmmmmk found out why the car leaned out in Fargo
            out of injector
            at my home elevation on 12psi i see a duty cycle of 85
            at 14psi i see 98-100
            (remember my current injectors are stable and linear up to 95%)
            so that is why with the elevation drop and 14.5psi i was over the top and leaned out at Fargo
            so it made me feel good to find out what was up
            static is 43psi right now, not sure if i will bump the static or get the ID2000s
              bought a gopro, made some vids today..... fucking jews make you buy the add on screen. retarded
              yes on the second vid no screen so i had no idea where the fuck it was pointed :poke:
              weird from the first vid how you can tell the car drops the passenger rear on gas
              My Great Movie 3
              road3
                ready for sky diving
                  here is my chute mount/class 3 hitch, haha
                  turned out well
                  think i will add some sort of eyelet on the inner shaft so that i can hook a ratchet strap on each side when the car is on the trailer. it would make life super simple
                  • 63vette6 Offline
                    63vette6 Offline
                    63vette
                    Looks pretty heavy. 😞
                    You need to start looking where you can lose 150 lbs to get that 8.
                      Zac, weren't you running really low boost on your 9.20 pass? Or am I mistaken?
                        you are supposed to have a gameplan for me so i can get a 1.30 60ft out of it, haha
                        yeah 12-12.5psi, much more than that at Fargo's elevation i am out of injector though. Ill try bumping my bumping my fuel pressure up and see if the pump can handle it. If i can get it up to ~15psi that should get it done
                        so when is the 240 going to be under boost?
                          Get some more injector, newb. Just got my 950's in the other day.
                          As soon as the manifold is done. 🙂
                            I already have 1000s, lol
                            big high Z injectors are $$$$, and a converter to low Z can suck my wee wee
                              Oh you nanner. Go buy some ID2000s and run your 8 ;).
                                Lol, the wife would notice that one
                                all done
                                car has about an inch of dust on it...needs to be driven
                                  Did you finish the front half of the cage yet?
                                    No
                                    I received my halo and A pillar bars. The halo fits nice, I don't like the A pillar
                                    So it wont be done till I buy a bender, don't know when that will be
                                      I added all of my 25.5 bars myself, I just used a piece of 1/4" rod and bent it over my knee to make a pattern of the pipe I needed made, then brought the rod with me to the guy with the mandrel bender and had him make what I needed. You just need to find someone out in the backwoods where you live that has a bender. 🙂
                                        sadly no one around here does. it is going to stay as is until i get my own bender 😞
                                          changing a little bit of stuff
                                          had a Magnafuel 625 (4301), and now got a new 750 (4303). This will support over 1kwhp on E85. Good pumps
                                          and i plan to move my regulator up front at the same time trying to keep it not a hose monster. we will see how that goes
