New Stuff
haha, you still drive like shit. all you hear at idle is fuel pump(s)
haha, we can do it up. but after you win i want a ride.
Mmmmmmk found out why the car leaned out in Fargo
out of injector
at my home elevation on 12psi i see a duty cycle of 85
at 14psi i see 98-100
(remember my current injectors are stable and linear up to 95%)
so that is why with the elevation drop and 14.5psi i was over the top and leaned out at Fargo
so it made me feel good to find out what was up
static is 43psi right now, not sure if i will bump the static or get the ID2000s
bought a gopro, made some vids today..... fucking jews make you buy the add on screen. retarded
yes on the second vid no screen so i had no idea where the fuck it was pointed :poke:
weird from the first vid how you can tell the car drops the passenger rear on gas
63vette;326350 wrote:
Looks pretty heavy.
You need to start looking where you can lose 150 lbs to get that 8.you are supposed to have a gameplan for me so i can get a 1.30 60ft out of it, haha
PSiedTSi;326351 wrote:
Zac, weren't you running really low boost on your 9.20 pass? Or am I mistaken?yeah 12-12.5psi, much more than that at Fargo's elevation i am out of injector though. Ill try bumping my bumping my fuel pressure up and see if the pump can handle it. If i can get it up to ~15psi that should get it done
so when is the 240 going to be under boost?
zbrown;326353 wrote:
you are supposed to have a gameplan for me so i can get a 1.30 60ft out of it, hahayeah 12-12.5psi, much more than that at Fargo's elevation i am out of injector though. Ill try bumping my bumping my fuel pressure up and see if the pump can handle it. If i can get it up to ~15psi that should get it done
Get some more injector, newb. Just got my 950's in the other day.
As soon as the manifold is done.
Did you finish the front half of the cage yet?
I added all of my 25.5 bars myself, I just used a piece of 1/4" rod and bent it over my knee to make a pattern of the pipe I needed made, then brought the rod with me to the guy with the mandrel bender and had him make what I needed. You just need to find someone out in the backwoods where you live that has a bender.
sadly no one around here does. it is going to stay as is until i get my own bender
gonna be along the lines of like this
and breathers, adding a -12 to each valve cover, and it will go back to the exhaust valvers with braided SS.
here is the baffles i added, this is the one in the valvecover i added last year. I added the same thing to the other side now with the addition of the other breather
