  4. Holes in trunk lid?!?!?!?!
33 Posts 16 Posters 1.7k Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    it has holes for a stock wing, and its green not the color of my car. it would have to get sprayed inside and out.
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      rubber cement and grey duct tape. works on everything
        AntiBling
        92TSIpos wrote:
        dont be dumb. if you weld the holes the metal will warp. I have welded on bodies of cars before and it warped with the lowest heat possible. Your best bet is to get a new trunk lid.
        Not if you know what you are doing. I welded in a roll pan, and a filler piece for my tailgate handle with no warping at all.
        Dont tell people something cant be done just because you dont know how to do it right.
          harwood39H Offline
          harwood39
          anybody know wher ei can pick up a oem 2 door wing at? besides the dealership?
          Fargo, ND 58103
          701-429-3686
            jy
            • NickBN Offline
              NickBN Offline
              NickB
              about damn time you get rid of that 8 foot wing
              • 9 Offline
                9 Offline
                92TSIpos
                I have been a professional welder for two and a half years, i'm only 19 years old. I know how to weld, so dont judge if you dont know me or my abilities. I was welding with a lincoln 300 welder. It doesnt turn down any lower than 12 amps and still welded a hole up the size of a quarter. You want to talk welding we can go at it. 😄
                  harwood39H Offline
                  harwood39
                  my holes are a 1/4 of an inch so i dont think it will warp the metal to weld those up
                  Fargo, ND 58103
                  701-429-3686
                    AntiBling
                    Read your post, it doesnt say anything about your welder YOU used. Its just you telling him not to do it because you warped the metal on your car.
                    And you're 19 and you are a "professional" welder since you were 16? Seems to me a "professional" would know the basics of welding expansion and contraction that causes welding and would use the right equipment for the job.
                    I may not know you, but you stated your abilities yourself and tried to pass your opinion off as fact. Im telling him otherwise.
                    Just take your time, work in small tacks and move from side to side, let the welds air cool and you should be fine.
                    • legacy-user-33L Offline
                      legacy-user-33
                      Electrical tape since your car is some what black.
                      -Tin-
                      -IS300-Black on Gold-
                        harwood39H Offline
                        harwood39
                        i have black rubber plugs in the holes for now. they are the hoos side bumbers that you can pick up from macs. they are about the size of a nickel and are about a 16th to an 8th of an inch tall off of the trunk lid.
                        Fargo, ND 58103
                        701-429-3686
                          just wondering how you became a professional welder at 16 too???? welding can fuck up the metal on cars...but it can be fixed easily.....ever seen a car with shaved door handles...or anything shaved!??!
                          • 9 Offline
                            9 Offline
                            92TSIpos
                            I know that much, and I do know more than just "basics". I guess I should have put a little more detail into my post, I apologize for coming off as a dick, and "profesional is a little far fetched, I guess we can say skilled welder.
                            • 9 Offline
                              9 Offline
                              92TSIpos
                              I went to school for it and took the tests and became certified. I graduated at 16 also.
                                certified in what welds
                                • 9 Offline
                                  9 Offline
                                  92TSIpos
                                  welding not welds. sorry had to correct you 🙂
                                    no what welds are u certified in u just dont get certified in welding. u have to do diffirent welds that what i ment.. what kinda welding u do..
                                      if he is certified...im sure he can arc, mig, tig, oxy/ace, wire..underwater...haha okay i was kddin about the underwater.
                                        aliengotpsi
                                        Bryan left highschool a little early to go to job corp to become a welder. If you ever get a chance to look at SleeperMX6's FMIC, he built the end tanks on it. That does him justice enough.
                                        -Joel under Kevin's name
                                        Kevin Smith
                                        Straightlinedetailing.com
