  4. Holes in trunk lid?!?!?!?!
33 Posts 16 Posters 1.7k Views
  • 9 Offline
    9 Offline
    92TSIpos
    dont be dumb. if you weld the holes the metal will warp. I have welded on bodies of cars before and it warped with the lowest heat possible. Your best bet is to get a new trunk lid.
      harwood when you were trying to sell ur car...you said it came with a extra trunk lid with no holes?!
      • harwood39H Offline
        harwood39H Offline
        harwood39
        it has holes for a stock wing, and its green not the color of my car. it would have to get sprayed inside and out.
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
          rubber cement and grey duct tape. works on everything
            AntiBling
            Not if you know what you are doing. I welded in a roll pan, and a filler piece for my tailgate handle with no warping at all.
            Dont tell people something cant be done just because you dont know how to do it right.
              harwood39H Offline
              harwood39
              anybody know wher ei can pick up a oem 2 door wing at? besides the dealership?
              Fargo, ND 58103
              701-429-3686
                jy
                • NickBN Offline
                  NickBN Offline
                  NickB
                  about damn time you get rid of that 8 foot wing
                  • 9 Offline
                    9 Offline
                    92TSIpos
                    I have been a professional welder for two and a half years, i'm only 19 years old. I know how to weld, so dont judge if you dont know me or my abilities. I was welding with a lincoln 300 welder. It doesnt turn down any lower than 12 amps and still welded a hole up the size of a quarter. You want to talk welding we can go at it. 😄
                      harwood39H Offline
                      harwood39
                      my holes are a 1/4 of an inch so i dont think it will warp the metal to weld those up
                      Fargo, ND 58103
                      701-429-3686
                        AntiBling
                        Read your post, it doesnt say anything about your welder YOU used. Its just you telling him not to do it because you warped the metal on your car.
                        And you're 19 and you are a "professional" welder since you were 16? Seems to me a "professional" would know the basics of welding expansion and contraction that causes welding and would use the right equipment for the job.
                        I may not know you, but you stated your abilities yourself and tried to pass your opinion off as fact. Im telling him otherwise.
                        Just take your time, work in small tacks and move from side to side, let the welds air cool and you should be fine.
                        • legacy-user-33L Offline
                          legacy-user-33
                          Electrical tape since your car is some what black.
                          -Tin-
                          -IS300-Black on Gold-
                            harwood39H Offline
                            harwood39
                            i have black rubber plugs in the holes for now. they are the hoos side bumbers that you can pick up from macs. they are about the size of a nickel and are about a 16th to an 8th of an inch tall off of the trunk lid.
                            Fargo, ND 58103
                            701-429-3686
                              just wondering how you became a professional welder at 16 too???? welding can fuck up the metal on cars...but it can be fixed easily.....ever seen a car with shaved door handles...or anything shaved!??!
                              • 9 Offline
                                9 Offline
                                92TSIpos
                                I know that much, and I do know more than just "basics". I guess I should have put a little more detail into my post, I apologize for coming off as a dick, and "profesional is a little far fetched, I guess we can say skilled welder.
                                • 9 Offline
                                  9 Offline
                                  92TSIpos
                                  I went to school for it and took the tests and became certified. I graduated at 16 also.
                                    certified in what welds
                                    • 9 Offline
                                      9 Offline
                                      92TSIpos
                                      welding not welds. sorry had to correct you 🙂
                                        no what welds are u certified in u just dont get certified in welding. u have to do diffirent welds that what i ment.. what kinda welding u do..
                                          if he is certified...im sure he can arc, mig, tig, oxy/ace, wire..underwater...haha okay i was kddin about the underwater.
