  4. Holes in trunk lid?!?!?!?!
33 Posts 16 Posters 1.7k Views
  • NickBN Offline
    NickBN Offline
    NickB
    about damn time you get rid of that 8 foot wing
    • 9 Offline
      9 Offline
      92TSIpos
      AntiBling wrote:
      Not if you know what you are doing. I welded in a roll pan, and a filler piece for my tailgate handle with no warping at all.
      Dont tell people something cant be done just because you dont know how to do it right.
      I have been a professional welder for two and a half years, i'm only 19 years old. I know how to weld, so dont judge if you dont know me or my abilities. I was welding with a lincoln 300 welder. It doesnt turn down any lower than 12 amps and still welded a hole up the size of a quarter. You want to talk welding we can go at it. 😄
      • harwood39H Offline
        harwood39H Offline
        harwood39
        my holes are a 1/4 of an inch so i dont think it will warp the metal to weld those up
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
          AntiBling
          Read your post, it doesnt say anything about your welder YOU used. Its just you telling him not to do it because you warped the metal on your car.
          And you're 19 and you are a "professional" welder since you were 16? Seems to me a "professional" would know the basics of welding expansion and contraction that causes welding and would use the right equipment for the job.
          I may not know you, but you stated your abilities yourself and tried to pass your opinion off as fact. Im telling him otherwise.
          Just take your time, work in small tacks and move from side to side, let the welds air cool and you should be fine.
          • legacy-user-33L Offline
            legacy-user-33
            Electrical tape since your car is some what black.
            -Tin-
            -IS300-Black on Gold-
              harwood39H Offline
              harwood39
              i have black rubber plugs in the holes for now. they are the hoos side bumbers that you can pick up from macs. they are about the size of a nickel and are about a 16th to an 8th of an inch tall off of the trunk lid.
              Fargo, ND 58103
              701-429-3686
                just wondering how you became a professional welder at 16 too???? welding can fuck up the metal on cars...but it can be fixed easily.....ever seen a car with shaved door handles...or anything shaved!??!
                • 9 Offline
                  9 Offline
                  92TSIpos
                  I know that much, and I do know more than just "basics". I guess I should have put a little more detail into my post, I apologize for coming off as a dick, and "profesional is a little far fetched, I guess we can say skilled welder.
                  • 9 Offline
                    9 Offline
                    92TSIpos
                    I went to school for it and took the tests and became certified. I graduated at 16 also.
                      certified in what welds
                      • 9 Offline
                        9 Offline
                        92TSIpos
                        welding not welds. sorry had to correct you 🙂
                          no what welds are u certified in u just dont get certified in welding. u have to do diffirent welds that what i ment.. what kinda welding u do..
                            if he is certified...im sure he can arc, mig, tig, oxy/ace, wire..underwater...haha okay i was kddin about the underwater.
                              aliengotpsi
                              Bryan left highschool a little early to go to job corp to become a welder. If you ever get a chance to look at SleeperMX6's FMIC, he built the end tanks on it. That does him justice enough.
                              -Joel under Kevin's name
                              Kevin Smith
                              Straightlinedetailing.com
