  4. Clutch Chatter
Clutch Chatter
24 Posts 10 Posters 812 Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    Ok. So i noticed that i had a chattering/knocking coming from the front of my car. I thaught it was just somthing being loose, but no, everthing was fine. So i drove around a little and figured out that it happens when i am engaging the clutch. Also, if the clutch pedal isnt all the way to the floor, it vibrates with the chattering. But it doesnt chatter or anything when its fully engaged or even when the pedal is all the way to the floor, fluids are fine. It first started durring the track day on memorial day.
    Oh ya, i forgot to mention that it doenst slip at all when it is fully engaged. Its just fine.
    And i dont want to hear this stupid shit about me abusing it torbs. I know its been abused, plus it is the stock clutch.
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      so replace it.
      • TsiTomT Offline
        TsiTomT Offline
        TsiTom
        ^^^second that
        Tom Opgrand
        2011 Camry
          harwood39H Offline
          harwood39
          i know i need to replace it, but i want to know what would have caused it
          Fargo, ND 58103
          701-429-3686
            harwood39H Offline
            harwood39
            i take it i cant drive it in the condition that its in? i mean its just chattering
            Fargo, ND 58103
            701-429-3686
              what caused it...look at the odometer.....
                harwood39H Offline
                harwood39
                true, 122k
                Fargo, ND 58103
                701-429-3686
                  I had one that made that noise. I broke the pressure plate into two pieces.
                    harwood39H Offline
                    harwood39
                    ^^^wow
                    i dont think its my pressure plate thats broken, i think its a worn bearing. But i could be wrong.
                    Fargo, ND 58103
                    701-429-3686
                      It also could be one of the cv axles. The inner joint can do the same thing after some reptative hard lanches.
                      • hondaking424H Offline
                        hondaking424
                        could be from all the fast shifting u do if your aways racing
                          harwood39H Offline
                          harwood39
                          This is ecactly what it is, checked it out today. Its the inner CV joint. Time to buy new axles. Now i just need to find some aftermarket ones, stock ones SUCK.
                          Fargo, ND 58103
                          701-429-3686
                            usually cv joints just make a clicking noise...well my monte carlo just made clicking noises anywaysa.
                              That's if it's the outer joints. I was refering to the inner ones. They wont click on you very often but they will cause all sorts of other problems when the get bad and bind up on you as is the caes here I believe.
                                What would you know about stock axles sucking?
                                I make 540 whp on stock axles and have raced on the same pair for 3 years. Tufte races on stock axles making 260 whp and hasn't broke one yet either.
                                Don't blame the stock part.
                                  harwood39H Offline
                                  harwood39
                                  Ya, i need to get them by the 18th so i can have fun on the track day, dont want to be running on bad cv joints.
                                  Fargo, ND 58103
                                  701-429-3686
                                    harwood39H Offline
                                    harwood39
                                    so should i run remanufactured ones(limited lifetime warranty)--$60, new ones(LLT)--$80, or Performance ones(3-month)--$200? All prices are for one side only
                                    Fargo, ND 58103
                                    701-429-3686
                                      Remans. You make 12 whp.
                                        lol ^
                                          get the cheapest ones........
