  4. Motor choice
Motor choice
56 Posts 22 Posters 2.0k Views
  • krzydrftr93K Offline
    krzydrftr93
    im thinking the b18c1 is sounding good. Are they quick stock?
    Matt
    92 Civic HB
    JDM d15b w/14b@8psi
      170hp
        krzydrftr93
        that would move a hatch pretty good wouldnt it. I mean yait should move it a lot better then the d15 91 hp moves it. What do you think i could run in the 1/4 with the b18c1?
        Matt
        92 Civic HB
        JDM d15b w/14b@8psi
          I don't know times, but yeah that would move a hatchback quite well.
          • civtegraC Offline
            civtegraC Offline
            civtegra
            My hatch has a blown head gasket and it ran a 15.5 with a header and a short cold air intake. i guess from wut i heard not sayin its true but i heard that a htch wit a b18c1 should make a high 14 aec in a 1/4
            • PhatsP Offline
              PhatsP Offline
              Phats
              14 flat is what 2 guys that did their gsr swaps ran.....with moderate supporting mods, suspension.....intake exhaust header etc.......
              02 GSXR-1000
              97 540i
                krzydrftr93
                14 sec hatch pretty much stock. Well i can beat ricer mustang then. LOL that would be shane. That is cool. 14 is a lot better then the 20 eclipse
                Matt
                92 Civic HB
                JDM d15b w/14b@8psi
                  krzydrftr93
                  Does anyone know where i can get the following complete swap cheaper:
                  B18C 94-97 (GSR) Complete Change Over
                  Price: $ 3149.00 Plus shipping and handling.
                  Availability: In stock and ready to go.
                  • Motor
                  • Hydraulic Tranny (S80, Y80)
                  • ECU (P72)
                  • Axles with Half Shaft
                  • Shift Linkage
                  • Stock Motor Mounts *
                  • Alternator
                  • Starter
                  • Clutch
                  • Flywheel
                  • Intake Manifold
                  • Exhaust Manifold
                  • Fuel Rail
                  • Injectors
                  • Distributor
                  • Engine Harness
                  • Comes With All Sensors Needed
                  • LSD Tranny (Optional +$300)
                  Motors average 35,000 miles and come with a 100% start up warranty. All Sensors are guaranteed not broken and in working condition!
                  • Please Note: We now offer the Hasport Hydraulic tranny to cable car conversion kit for $429. Also available is the Hasport High Horsepower upgraded motor mount kit for $300.
                  thanks
                  Matt
                  92 Civic HB
                  JDM d15b w/14b@8psi
                    That's a good deal on the motor. However when you do that you are going to want to do the following:
                    Headgasket
                    Timing Belt
                    Alternator Belt
                    and a Clutch
                    Those are the 4 things I recommend on EVERY swap. Because you really have no idea how many miles are on the motor, how long its sat, etc.
                    • civtegraC Offline
                      civtegraC Offline
                      civtegra
                      Headgasket
                      Timing Belt
                      Alternator Belt
                      and a Clutch
                      yeah that is very true.
                        Buying/looking for the cheapest swap out there is just not going to be in your best interest. Buy the most complete and best warrantied swap regardless of price unless you wanna buy twice.
                          yeah most of them say they have 30-50k....but usually have 130-150k on them....there are soem cheaper places than that i think they offer a 6 month warranty also.
                          And include all of those parts also.
                          If u buy a motor...make sure everything that is supposed to come with it actually comes with it....otherwise you gotta spend more money that you shouldnt have to!
                            How do you know that about the mileage?
                            • harwood39H Offline
                              harwood39H Offline
                              harwood39
                              i want to know that too. how do oyu know about the milage?
                              2730 5th Ave S. Unit C
                              Fargo, ND 58103
                              701-429-3686
                                If it actually is from Japan, there's a good chance it has under 80,000 mile on it. Over there they don't have near as strict of an emissions law so there engines produce more power usually. The down side for them, (an upside for us) is that when the car gets any higher of mileage, their gov't taxes the hell out of them to run that same engine so it actually becomes cheaper to either drop in a new engine and/or get a whole new car all together. Now this is by no means etched in stone but it is a good rule of thumb. And a better warranty and more complete swap is diffinately worth the xtra $$$.
                                  might want to look for a front-clip of a car that was known to be in good running order before it was tboned of hit from behind. usually a little more expensive than buying a swap, but you get everything, and often you get more than you expected (heavier than stock clutch, etc)
                                  • h22d_hatchH Offline
                                    h22d_hatchH Offline
                                    h22d_hatch
                                    Hmotors is a awesome place to do business with.
                                      I personally have no clue what you are talking about. A b-16? Go blow yourselves with a vortech, that usually helps a lot of people.
                                      Remember old school mustang guy here. Some people don't know what a carb is, others have no clue what these number thngs you speak of are.
                                        supercharger = parasitic drag to produce power = not the best for a 4cyl
