  3. Run Your Mouth
  4. I would like everyone's opinion
51 Posts 36 Posters 6.7k Views
  • 24valvenotak2
    24valvenotak2
    HandoEX wrote:
    "I'd have sex with two girls at the same time!"
    -Lawrence, Office Space
    I was going to say that same thing..
    I would throw some money at my car..probably quite a bit
    then,
    M3 + bling bling
    evo/sti + tons of tires and brakes
    F350 + "banks" and chrome
    GTI R32 + a TON of money
    boat + ski rope
    jet ski + trailer
    CBR + helmet and band aides
    63vette;288530 wrote:
    • LightEmUpL
      LightEmUpL
      LightEmUp
      I would get.......
      1969 camaro Z28 RS/SS Copo
      That would put me about 750,000 over budget lol jk
      For real I would buy a
      1970 trans am (50,000)
      1970 GTO Judge (70,000)
      1067 Camaro RS/SS 454 (100,000)
      and the last 30,000 I would just have for extra money
      1975 Trans am 455 8.99 @158mph (What now fallguy)
      1987 CRSEX W/Fucking VVVVVVVVV-TEC (But is now sitting in a junk yard cuz I blew it up......Ooops!!)
      2001 cr125 (Faster Than LoveMachines Bike)
      • 3_Series3
        3_Series3
        3_Series
        Hennessey Venom 1000 Twin Turbo SRT Coupe (225,000)
        top speed 255mph! rest would be for gas.
        2002 Subaru Legacy
        1993 BMW 325i (sold)
        • FlowcusF
          FlowcusF
          Flowcus
          That car isnt real... the world record holder for top speed is the Koenigsagg CCR with 242mph. I have the Car and Driver with it in there... such a kick ass car!
          I ride random bitches.
            I'd keep my car, New shelby gt500, new ford gt There is enough there for parts and research work on I'd say 7 shelby's (any year)in restorable condition from the 60's.
            • 3_Series3
              3_Series3
              3_Series
              well the 255mph figure is theoretical of course, but i wouldn't bet against a car with 1000hp/1100tq if you give it enough pavement.
              2002 Subaru Legacy
                My money is FIRMLY on the Koenigsegg CCR
                Performance
                Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds
                Top speed: 395+ km/h (242+ mph)
                Standing quartermile: 9 seconds, end speed 235 km/h (146 mph)
                Braking distance: 31 m (100–0 km/h)
                Lateral g-force: 1.3 g
                Fuel consumption: Highway travel: 13 l/100 km
                Combined: 17 l/100 km
                Body
                Two-door, two-seater with removable hardtop stowable under the front boot lid. 	The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam 	sandwich reinforcements.
                 	**Dimensions**
                Ground clearance: 100 mm (3.9 inch)
                Fuel capacity: 80 litres (17.6 gallons)
                Luggage compartment: 120 litres (26.4 gallons)
                Dry weight: 1180 kg
                Areodynamics
                Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis. 	Venturi tunnels at the rear of chassis/body.
                Chassis
                Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
                Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
                Brakes
                Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
                Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control syste
                Wheels
                Koenigsegg magnesium alloy wheels with centre locking.
                Front: 19” x 9.5”
                Rear: 20” x 12.5”
                Tyres
                Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
                Front: 255/35–19” (Y)
                Rear: 335/30–20” (Y)
                Steering
                Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres.
                Engine (click for more info about the CCR engineering specifics)
                Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
                Displacement: 4.700 cm3.
                Compression: 8.6:1
                Weight: 215 kg
                Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
                Oil: SAE 10W60 fully synthetic racing.
                Oil tank capacity: 12 litres (2.64 gallons)
                Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.
                Fuel: 98 RON unleaded.
                Ignition system: Direct coil on plug. Transistorised.
                Power output: 806 bhp at 6.900 rpm.
                Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
                Maximum rpm: 7.600 rpm.
                Transmission
                Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
                Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch). Oil-cooled and electronically operated.
                Equipment
                In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
                Standard equipment
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Aluminium rear light casings
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Detachable roof panel
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Climate control
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Electric rear view mirrors
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Leather interior
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Central locking
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Electrical windows
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Alarm with immobilizer
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Toolkit
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Driver side airbag
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Power steering
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Hydraulic ride height control
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Servo assisted brakes
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) ABS
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Traction control
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Stereo with CD-player
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Tyre pressure sensors
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Car cover
                Customer options
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Custom Color Leather Interior
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Custom Paint Color
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Parking Sensors
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) GPS Navigation
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Sequentially operated gearbox
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Rearview Camera
                ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Fitted Luggage
                Whats not to love?
                • SaxGopherS
                  SaxGopherS
                  SaxGopher
                  Ariel Atom... just because...
                  With whatever's left over I think I'd try to find a FIA Rally-Spect WRC Evo 6.5... Either that or just import an Evo 6 TME and drop a few grand into that and buy a normal evo for a daily driver...
                  Or the Koenigsegg... yeah... that'd be sweet...
                  P.S. Anyone seen the Top Gear where he drove the Atom? A-freaking-mazing...
                  03 Evo VIII w/ bolt-ons. :icon_thumleft:
                  • ichibankillaI
                    ichibankillaI
                    Well me, I always try to lean toward something a little different, something you don't see every day. It's a name we all know and love but it's type that's rarely seen.
                    Two words: "Oldschool" Skyline 😄
                    legacy image legacy image legacy image
                    Plus I'm sure I'd a few bucks left to build a garage to keep it in.
                    • 3_Series3
                      3_Series3
                      3_Series
                      Performance
                      Body
                        **Dimensions**
                      Dry weight: 1180 kg
                      Areodynamics
                      Chassis
                      Brakes
                      Wheels
                      Front: 19” x 9.5”
                      Rear: 20” x 12.5”
                      Tyres
                      Steering
                      Compression: 8.6:1
                      Weight: 215 kg
                      Transmission
                      Equipment
                      Standard equipment
                      legacy image Aluminium rear light casings
                      legacy image Detachable roof panel
                      legacy image Climate control
                      legacy image Electric rear view mirrors
                      legacy image Leather interior
                      legacy image Central locking
                      legacy image Electrical windows
                      legacy image Alarm with immobilizer
                      legacy image Toolkit
                      legacy image Driver side airbag
                      legacy image Power steering
                      legacy image Hydraulic ride height control
                      legacy image Servo assisted brakes
                      legacy image ABS
                      legacy image Traction control
                      legacy image Stereo with CD-player
                      legacy image Tyre pressure sensors
                      legacy image Car cover
                      Customer options
                      legacy image Custom Color Leather Interior
                      legacy image Custom Paint Color
                      legacy image Parking Sensors
                      legacy image GPS Navigation
                      legacy image Sequentially operated gearbox
                      legacy image Rearview Camera
                      legacy image Fitted Luggage
                      Whats not to love?
                      yes the CCR is a great car, and top speed wise you are probably correct, it would be a stretch for the Viper to reach that speed without carefully designed aerodynamics, but for the $250000 price ceiling, the Viper gets my money.
                      if I had unlimited resources I'd get a Bugatti Veyron. Quad turbo W16! 987 SAE HP. Projected top speed (with specially developed tires) 253mph.
                      2002 Subaru Legacy
