  4. nsx engine?
nsx engine?
95 Posts 19 Posters 7.6k Views
    There is not very much information out about k20 turbo's since they are such a new engine. I know that Gredy makes a kit for the k20.
      isnt the type s 200hp?
      maybe im retarded or both
        Here is where I got my infromation.
        http://www.clubcivic.com/board/specs.php
          yeah i believe its a different motor for the type s...well i mean its still the k20
            the Si k20 is the same as the stock rsx i believe too
            • AcesHighA Offline
              AcesHighA Offline
              AcesHigh
              out there wrote:
              boost magazine (from car & driver i think...) put a supercharger on the k20 and ran like 4.7 psi. actually, there have a been some arguments on honda-tech about which is better for a turbo: high or low compression. low compression means more boost for xxxhp with significant lag, whereas higher compression means less boost for xxxhp with a little less lag. i think the #'s were 9:1 vs 10:1
              granted, many other factors come into play (fuel mainly), but that was the basis for the argument
              High Boost + High Compression = High Horsepower (teh win), but the problem runs with detonation. Which is why you'd need race fuel to counter it.
              My original impression was that the K24A was in base, and the high revving VTEC K20 was in type S. Like in Preludes. But I guess both base and type S have a different version of the same engine, K20x.
                the k20 is in the regular RSX and has 160 hp
                and the k24 is in the Type S and has 200 hp
                from what i have heard and seen i must be wrong.
                  if ur going to do a motor swap get a h22 i have one and they pull like nothing eles
                    I for one beg to differ....
                      nvsgsx...nope the type s is still a 2liter
                      why would he swap from a 200hp k20 to an H22?
                      doesnt the k20 have something different like i-VTEC...im not sure what exactly has changed but id like to see someone mess around with that motor a little bit and i bet youd get some good results...
                      • NickBN Offline
                        NickBN Offline
                        NickB
                        im gonn have to agree with boomer on this one...
                          [QUOTE=PSiedTSi]nvsgsx...nope the type s is still a 2liter
                          QUOTE]
                          okay thanks i wasnt really sure..
                          but the H22 is OVERRATED....and old!
                          just get the k20 and get a turbo kit!
                            well if u like k20 200hp over the h22 220hp. i guess i would take the h22 but thats a prelude motor who puts a h22 in a rsx i dont no there both great motors 😄
                              nvs he already has the K20...he just needs more powa
                                I-VTEC>VTEC
                                I-VTEC is very new, as in 2002 it was released when the 2002 HB Si came out. The k20 and the k24 are awsome engines and have tons of potential. ( Correct me if I'm wrong )
                                VTEC has been around since 88 in japan. H22 is a great engine but I'm pretty sure that no one makes mounts for a RSX H22 swap. And WHY WOULD THEY?
                                <u>Boost the bitch!</u>
                                  the k24 is for the element, tsx and accord just to help clarify
                                    I dont exactly know what year ken's dad's RSX-S is, but the 05's have 210 HP stock and the iVTEC. The iVTEC stands for intelligent VTEC. From Acura's website :
                                    For the RSX and RSX Type S, The Acura Engineers took the VTEC technology to the next level. Rather than adjusting valve lift, timing and duration at a specific RPM, this cutting-edge technology adjusts constantly depending on engine speed.
                                    • NickBN Offline
                                      NickBN Offline
                                      NickB
                                      yeah i vtec is pimp..my bros car kicked my ass
                                      • theobliviousT Offline
                                        theoblivious
                                        210 horses now! sigh 05 why 05 why not 06. yeah the rsx im getting is the type s with 200 horses. its an 02. so you guys suggest i go with the original motor in it? i believe its k20 from what im understanding. Im not however very familiar with turbo and where the greatest gains will be. but from what i have learned, if i can get a v 6 in under the hood, i can have two turbos sequential therefore reducing turbo lag. While having one fat ass turbo would create a lot of lag. Am i correct in what im saying, cause i still dont know very much. thanks for the help.
                                        BOOST....to be continued
                                        • D Offline
                                          D Offline
                                          dynasty_v6
                                          Oh boy, only type S makes that power. Plus there's plenty of people putting 300+ whp on stock bottom end rsxs and they run an even higher compression than a regular h22
