  4. nsx engine?
nsx engine?
95 Posts 19 Posters 7.9k Views
    buy a honda civic and put the k20 motor in it....have you ever seen a civic with a 6 speed?? that would be awesome.
      I almost did a k20 swap into my 7th gen civic , lots of money but I was going to go through with it, but it was a LOT cheaper just to get the wrx and run better times with that.
        K20's are perfect for boost. One of my favorite engines!
        <u>K20a3</u>
        160@6500
        132@5000
        9.8:1
        2.0L 16-Valve
        DOHC VTEC
        Get it and turbo that bitch!
        • AcesHighA Offline
          AcesHighA Offline
          AcesHigh
          Bryce, that kind of compression would require low boost (which is the likely route) or a ridiculously high octane fuel. Although you'd probably see a rod punch a hole through the block before you'd experience detonation. The K24 would be better for a turbo, although I'm fairly certain that AFR is around the 10.0:1 mark as well.
            boost magazine (from car & driver i think...) put a supercharger on the k20 and ran like 4.7 psi. actually, there have a been some arguments on honda-tech about which is better for a turbo: high or low compression. low compression means more boost for xxxhp with significant lag, whereas higher compression means less boost for xxxhp with a little less lag. i think the #'s were 9:1 vs 10:1
            granted, many other factors come into play (fuel mainly), but that was the basis for the argument
              There is not very much information out about k20 turbo's since they are such a new engine. I know that Gredy makes a kit for the k20.
                isnt the type s 200hp?
                maybe im retarded or both
                  Here is where I got my infromation.
                  http://www.clubcivic.com/board/specs.php
                    yeah i believe its a different motor for the type s...well i mean its still the k20
                      the Si k20 is the same as the stock rsx i believe too
                      • AcesHighA Offline
                        AcesHighA Offline
                        AcesHigh
                        High Boost + High Compression = High Horsepower (teh win), but the problem runs with detonation. Which is why you'd need race fuel to counter it.
                        My original impression was that the K24A was in base, and the high revving VTEC K20 was in type S. Like in Preludes. But I guess both base and type S have a different version of the same engine, K20x.
                          the k20 is in the regular RSX and has 160 hp
                          and the k24 is in the Type S and has 200 hp
                          from what i have heard and seen i must be wrong.
                            if ur going to do a motor swap get a h22 i have one and they pull like nothing eles
                              I for one beg to differ....
                                nvsgsx...nope the type s is still a 2liter
                                why would he swap from a 200hp k20 to an H22?
                                doesnt the k20 have something different like i-VTEC...im not sure what exactly has changed but id like to see someone mess around with that motor a little bit and i bet youd get some good results...
                                • NickBN Offline
                                  NickBN Offline
                                  NickB
                                  im gonn have to agree with boomer on this one...
                                    [QUOTE=PSiedTSi]nvsgsx...nope the type s is still a 2liter
                                    QUOTE]
                                    okay thanks i wasnt really sure..
                                    but the H22 is OVERRATED....and old!
                                    just get the k20 and get a turbo kit!
                                      well if u like k20 200hp over the h22 220hp. i guess i would take the h22 but thats a prelude motor who puts a h22 in a rsx i dont no there both great motors 😄
                                        nvs he already has the K20...he just needs more powa
                                          I-VTEC>VTEC
                                          I-VTEC is very new, as in 2002 it was released when the 2002 HB Si came out. The k20 and the k24 are awsome engines and have tons of potential. ( Correct me if I'm wrong )
                                          VTEC has been around since 88 in japan. H22 is a great engine but I'm pretty sure that no one makes mounts for a RSX H22 swap. And WHY WOULD THEY?
                                          <u>Boost the bitch!</u>
