  4. nsx engine?
nsx engine?
95 Posts 19 Posters 7.9k Views
    if you wanted the nsx engine just get an acura TL typeS(basically same motor) and i believe its setup for fwd correct?
    • legacy-user-33L Offline
      legacy-user-33
      yup
      -Tin-
      -IS300-Black on Gold-
        Have fun haha.
          turbo. cheaper, easier, more power ^^see mr thompson for proof
            spoolude wrote:
            ok the nsx is a rear wheel drive car so that means u would have to make the rsx a rear wheel drive witch costs lots o money u should have sombody in town build u a LS v-tec they make lots of power but cost alot to do or somthing like that
            so you're telling him to sell his k20 motor to run an ls/vtec? that's one of the more retarded things I've ever heard. look into the power potential of your k20 motor, you have a good platform to build off of.
              explan k20 i dont know what it is
                Engine. Considerably more expensive then LS motor. I think some sponsor car (some rsx) just went 9's with it all motor.
                  buy a honda civic and put the k20 motor in it....have you ever seen a civic with a 6 speed?? that would be awesome.
                    I almost did a k20 swap into my 7th gen civic , lots of money but I was going to go through with it, but it was a LOT cheaper just to get the wrx and run better times with that.
                      K20's are perfect for boost. One of my favorite engines!
                      <u>K20a3</u>
                      160@6500
                      132@5000
                      9.8:1
                      2.0L 16-Valve
                      DOHC VTEC
                      Get it and turbo that bitch!
                      • AcesHighA Offline
                        AcesHighA Offline
                        AcesHigh
                        Bryce, that kind of compression would require low boost (which is the likely route) or a ridiculously high octane fuel. Although you'd probably see a rod punch a hole through the block before you'd experience detonation. The K24 would be better for a turbo, although I'm fairly certain that AFR is around the 10.0:1 mark as well.
                          boost magazine (from car & driver i think...) put a supercharger on the k20 and ran like 4.7 psi. actually, there have a been some arguments on honda-tech about which is better for a turbo: high or low compression. low compression means more boost for xxxhp with significant lag, whereas higher compression means less boost for xxxhp with a little less lag. i think the #'s were 9:1 vs 10:1
                          granted, many other factors come into play (fuel mainly), but that was the basis for the argument
                            There is not very much information out about k20 turbo's since they are such a new engine. I know that Gredy makes a kit for the k20.
                              isnt the type s 200hp?
                              maybe im retarded or both
                                Here is where I got my infromation.
                                http://www.clubcivic.com/board/specs.php
                                  yeah i believe its a different motor for the type s...well i mean its still the k20
                                    the Si k20 is the same as the stock rsx i believe too
                                    • AcesHighA Offline
                                      AcesHighA Offline
                                      AcesHigh
                                      High Boost + High Compression = High Horsepower (teh win), but the problem runs with detonation. Which is why you'd need race fuel to counter it.
                                      My original impression was that the K24A was in base, and the high revving VTEC K20 was in type S. Like in Preludes. But I guess both base and type S have a different version of the same engine, K20x.
                                        the k20 is in the regular RSX and has 160 hp
                                        and the k24 is in the Type S and has 200 hp
                                        from what i have heard and seen i must be wrong.
                                          if ur going to do a motor swap get a h22 i have one and they pull like nothing eles
