  4. nsx engine?
nsx engine?
95 Posts 19 Posters 7.6k Views
    spoolude wrote:
    ok the nsx is a rear wheel drive car so that means u would have to make the rsx a rear wheel drive witch costs lots o money u should have sombody in town build u a LS v-tec they make lots of power but cost alot to do or somthing like that
    so you're telling him to sell his k20 motor to run an ls/vtec? that's one of the more retarded things I've ever heard. look into the power potential of your k20 motor, you have a good platform to build off of.
      explan k20 i dont know what it is
        Engine. Considerably more expensive then LS motor. I think some sponsor car (some rsx) just went 9's with it all motor.
          buy a honda civic and put the k20 motor in it....have you ever seen a civic with a 6 speed?? that would be awesome.
            I almost did a k20 swap into my 7th gen civic , lots of money but I was going to go through with it, but it was a LOT cheaper just to get the wrx and run better times with that.
              K20's are perfect for boost. One of my favorite engines!
              <u>K20a3</u>
              160@6500
              132@5000
              9.8:1
              2.0L 16-Valve
              DOHC VTEC
              Get it and turbo that bitch!
              • AcesHighA Offline
                AcesHighA Offline
                AcesHigh
                Bryce, that kind of compression would require low boost (which is the likely route) or a ridiculously high octane fuel. Although you'd probably see a rod punch a hole through the block before you'd experience detonation. The K24 would be better for a turbo, although I'm fairly certain that AFR is around the 10.0:1 mark as well.
                  boost magazine (from car & driver i think...) put a supercharger on the k20 and ran like 4.7 psi. actually, there have a been some arguments on honda-tech about which is better for a turbo: high or low compression. low compression means more boost for xxxhp with significant lag, whereas higher compression means less boost for xxxhp with a little less lag. i think the #'s were 9:1 vs 10:1
                  granted, many other factors come into play (fuel mainly), but that was the basis for the argument
                    There is not very much information out about k20 turbo's since they are such a new engine. I know that Gredy makes a kit for the k20.
                      isnt the type s 200hp?
                      maybe im retarded or both
                        Here is where I got my infromation.
                        http://www.clubcivic.com/board/specs.php
                          yeah i believe its a different motor for the type s...well i mean its still the k20
                            the Si k20 is the same as the stock rsx i believe too
                            • AcesHighA Offline
                              AcesHighA Offline
                              AcesHigh
                              High Boost + High Compression = High Horsepower (teh win), but the problem runs with detonation. Which is why you'd need race fuel to counter it.
                              My original impression was that the K24A was in base, and the high revving VTEC K20 was in type S. Like in Preludes. But I guess both base and type S have a different version of the same engine, K20x.
                                the k20 is in the regular RSX and has 160 hp
                                and the k24 is in the Type S and has 200 hp
                                from what i have heard and seen i must be wrong.
                                  if ur going to do a motor swap get a h22 i have one and they pull like nothing eles
                                    I for one beg to differ....
                                      nvsgsx...nope the type s is still a 2liter
                                      why would he swap from a 200hp k20 to an H22?
                                      doesnt the k20 have something different like i-VTEC...im not sure what exactly has changed but id like to see someone mess around with that motor a little bit and i bet youd get some good results...
                                      • NickBN Offline
                                        NickBN Offline
                                        NickB
                                        im gonn have to agree with boomer on this one...
                                          [QUOTE=PSiedTSi]nvsgsx...nope the type s is still a 2liter
                                          QUOTE]
                                          okay thanks i wasnt really sure..
                                          but the H22 is OVERRATED....and old!
                                          just get the k20 and get a turbo kit!
