  4. nsx engine?
nsx engine?
95 Posts 19 Posters 7.9k Views
  • theobliviousT Offline
    theoblivious
    BOOST....to be continued
      theoblivious
      hey would the nsx engine fit in a rsx type s 2002? if you have any other suggestions that would be good engine swaps for the rsx would you give me your voice?
      Thanks
      Kenn
        That would be crazy, if you do decide to do this. SELL ME YOUR k20!
          theoblivious
          alright haha just wondering if it will work. i mean a 2 liter going to a 3.2 or 3.5 liter
            Lots of money, contact HAsport and see if they make any mount kit swaps or whatnot.
              ok the nsx is a rear wheel drive car so that means u would have to make the rsx a rear wheel drive witch costs lots o money u should have sombody in town build u a LS v-tec they make lots of power but cost alot to do or somthing like that
                I never hear of NSX swaps, cuz of the cost from RWD to FWD and other associated costs of converting a mid engine whatnot.
                  i dont even think it would fit its a in-line 6 right? but i dont think theres anybody in fargo that could do it.
                  what does the stock rsx put out?
                  • NickBN Offline
                    NickBN Offline
                    NickB
                    its a 3.2 v6
                      if you wanted the nsx engine just get an acura TL typeS(basically same motor) and i believe its setup for fwd correct?
                      • legacy-user-33L Offline
                        legacy-user-33
                        yup
                        -Tin-
                        -IS300-Black on Gold-
                          Have fun haha.
                            turbo. cheaper, easier, more power ^^see mr thompson for proof
                              so you're telling him to sell his k20 motor to run an ls/vtec? that's one of the more retarded things I've ever heard. look into the power potential of your k20 motor, you have a good platform to build off of.
                                explan k20 i dont know what it is
                                  Engine. Considerably more expensive then LS motor. I think some sponsor car (some rsx) just went 9's with it all motor.
                                    buy a honda civic and put the k20 motor in it....have you ever seen a civic with a 6 speed?? that would be awesome.
                                      I almost did a k20 swap into my 7th gen civic , lots of money but I was going to go through with it, but it was a LOT cheaper just to get the wrx and run better times with that.
                                        K20's are perfect for boost. One of my favorite engines!
                                        <u>K20a3</u>
                                        160@6500
                                        132@5000
                                        9.8:1
                                        2.0L 16-Valve
                                        DOHC VTEC
                                        Get it and turbo that bitch!
                                        • AcesHighA Offline
                                          AcesHighA Offline
                                          AcesHigh
                                          Bryce, that kind of compression would require low boost (which is the likely route) or a ridiculously high octane fuel. Although you'd probably see a rod punch a hole through the block before you'd experience detonation. The K24 would be better for a turbo, although I'm fairly certain that AFR is around the 10.0:1 mark as well.
