  4. Car sputters
Car sputters
33 Posts 11 Posters 2.2k Views
  • krzydrftr93K Offline
    krzydrftr93
    Ill be driving along in 2nd and it will be sputtering a little and whenever i punch it, it does it more and then accelerates 😕
    Anyone know why this is or what it is? It does it in 3rd sometimes to but now as much/bad.
    Matt
    92 Civic HB
    JDM d15b w/14b@8psi
      check plugs/wires for starters
        krzydrftr93
        OK...If my memory is good, when I bought the car the guy mentioned something about oil getting the distributor cap or something. Could that be possible to?
        Matt
        92 Civic HB
        JDM d15b w/14b@8psi
        • lord_deastofactL Offline
          lord_deastofact
          my car used to do that when you punched it, turned out one of the spark plugs was just bad... might be just that simple of a fix.
          and yeah it would only do it when you got on it.
          Minute ricer!
            krzydrftr93
            Thanks for the help 🙂 I will check this stuff out and ill let you know if it stops or not. Thanks again
            Matt
            92 Civic HB
            JDM d15b w/14b@8psi
            • darkelvisD Offline
              darkelvisD Offline
              darkelvis
              check plugs, wires, dizzy, and timing/timing belt. 🙂
              • youngin2nrY Offline
                youngin2nrY Offline
                youngin2nr
                my car did it for awhile until i replace the catylatic convertor and flex tube. Now the mazda flows smooth. Check that too.
                :3gears: -> :drink: -> :poon:
                  krzydrftr93
                  Ok this probably seems really dumb but how do you know if the wires are bad or not?
                  Matt
                  92 Civic HB
                  JDM d15b w/14b@8psi
                    Disconnect each spark plug wire off and measure resistance between the 2 ends of the wire. Resistance should be less than 25000 ohms on each wire.
                      seanjohn
                      Exactly what my car did. Rotor cap, take it off and take a look at it now before the problem becomes more serious.
                        TEG2LOW
                        Even if the plugs have spark the won't always fire under load, so replace em if not any of the other problems.
                          krzydrftr93
                          Ok..I just got the new plugs and wires on, took it for a spin and its still doing it. Anyone know what else it might be?
                          Jake-did you have this same problem with it?
                          Matt
                          92 Civic HB
                          JDM d15b w/14b@8psi
                          • tntmstrT Offline
                            tntmstrT Offline
                            tntmstr
                            check your distributor cap and rotor, replace your fuel filter, check ALL of your engine grounds that's what i would start with..........................................or u can always bring it to tintmasters and i'll fix it
                            kyle posting at work
                            Jason Christopherson
                            Store Manager
                            Tintmasters
                            Fargo, ND (701)239-TINT
                            www.tintmasters.net
                              krzydrftr93
                              I dont want to have to pay labor to have it fixed when I can do it myself if I just find out what it is. Sorry
                              Matt
                              92 Civic HB
                              JDM d15b w/14b@8psi
                              • nuckinfutsN Offline
                                nuckinfutsN Offline
                                nuckinfuts
                                hey yea i had the same problem when i had the car, a buddy of mine said that he had the same problem too, he just said that there was oil in the distributer cap and all he did was clean it out and it worked just fine. i just never got aroumnd to doing that before i sold u the car.now my new car is stating to do it too so ill try it out and let u know.
                                  seanjohn
                                  I swear to god it's your distributor.
                                    krzydrftr93
                                    If its the distributor, I would have to replace both cap and the rotor right??
                                    Matt
                                    92 Civic HB
                                    JDM d15b w/14b@8psi
                                      seeming as how that is what a dizzy really is....yeaaahhh. Just ebay it up and buy a new dizzy.
                                        http://cgi.ebay.com/ebaymotors/96-97-98-HONDA-CIVIC-DISTRIBUTOR-1-6-D16-VTEC_W0QQitemZ8024947439QQcategoryZ33690QQrdZ1QQcmdZViewItem
                                        Theres a really cheap Dizzy thats ending soon, just save the time and buy it.
                                          krzydrftr93
                                          Thanks, but I will just buy a brand new one. I would rather have new parts or aftermarket parts. And would that dizzy even work on my car considering its a 1.5 d15 NOT 1.6 d16
                                          Matt
                                          92 Civic HB
                                          JDM d15b w/14b@8psi
