  4. Corrosions on battery
17 Posts 14 Posters 807 Views
    Go to a car wash and degrease it and spray it off..
    • itRfanI Offline
      itRfanI Offline
      itRfan
      it may sound carzy, but my dads old mechanic told him the way to get rid of "corrosion" on a battery is to use COCA COLA i guess it eats it right up, i did it on my old battery in my sable and it worked pretty good, kinda ghetto but it's a thought 😛
      -weshole
        that's the way i was taught too haha
          coke works, wire brush works also..
          • itRfanI Offline
            itRfanI Offline
            itRfan
            GHETTO, i guess is our middle name huh? 😉
            -weshole
              I heard that if you get it really wet, and then hold on to the ground while you lick the postive post it zaps it right off...
                tin baking soda doesnt get rid of the corrosion it just neutralizes the acid...
                  didnt mr miller teach you anything?
                  • darkelvisD Offline
                    darkelvisD Offline
                    darkelvis
                    degreaser and a battery post cleaner, coke only works as good as water, but it also attracts ants. 🙂 I asked a master tech this same question this past summer.
                      Mythbusters yesterday covered this....soda and water was far superior to Coca Cola for removing the deposits, however the only way to get them "clean" was with a wire brush or a terminal cleaner.
                        aliengotpsi
                        I said Degreaser and a pressure washer enough said............... NO one needs to post !!
                        Why pour pop on it ? then it will get sticky.. Do what I said..
                        Kevin Smith
                        Straightlinedetailing.com
                          i posted
                            wd-40 and then coat it with vaseline to protect it.
                              pin
                              I had a problem with corrosion on my battery terminals for years. I had my car in the shop at an Interstate Battery store when they determined it was bad, and they installed felt washers along with the new battery. I've had no corrosion problem at all since then. Those washers are less than $3.
                              Barry
                                get anticorrosion rings. Can be bought anywhere that sells car stuff for 2 bucks.
