  4. 150 miles to my last tank?!
20 Posts 12 Posters 1.4k Views
    seanjohn
    Just replaced the o2 sensors I had in my car with some fresh ones...figured a little maintenence wouldn't hurt anyone. Well, after replacing them with some universal bosch's I got around 150 to the tank which is pretty unusual beings I usually get 240ish. I suspect the o2 sensors...is there any way I can check them????
      Well, I would say put the old ones back in.
        seanjohn
        Old ones are coated with carbon from running a piss-poor tune. I had heard that bosch's don't agree with honda's....but what I really need to know is if I can simply have these tested...where, and how much.
        • bluejaysB Offline
          bluejaysB Offline
          bluejays
          bosch doesn't agree with any car imo
            seanjohn
            Anyone have any experience w/ denso's?
            • JohnWJ Offline
              JohnWJ Offline
              JohnW
              go with some OEM ones. try resetting your ecu if you can. i'm not too familiar with hondas but it took my gsx a little while to get used to the idea of my new o2 sensor. just some thoughts.
              90 Civic DX hatch
              D16a6/y8 mini me
                seanjohn
                OEM is an idea, but they don't come w/ a warranty....ever. Also, these bosch's have a warranty on them, so I should be able to replace them with something else at autozone...i.e. denso's
                • Sweet-WRX-LovinS Offline
                  Sweet-WRX-Lovin
                  You're not out of boost fluid again right?
                  One time...
                  • XJHEADX Offline
                    XJHEADX Offline
                    I wish I could get 150 miles to a tank
                      slowvo
                      there is zero warranty on OEM o2 sensors?
                      damn...honda is gay
                      • JohnWJ Offline
                        JohnWJ Offline
                        JohnW
                        Yeah, check out your vtak cleaner too. I heard honda is going to stop selling the vtak cleaner so stock up now.. after this year you will just have to buy a new vtak. (or go grey market for 'tak cleaner... shhh).
                        Just funnin.. I had a civic ex when I was 17 and didn't know shit about cars and let me tell you, v-tec was the shit.
                        90 Civic DX hatch
                        D16a6/y8 mini me
                          A way you can check to see if they are putting out the proper voltage, is to use a multi meter, and read the signal wire at the ECU to see if it is fluctuating between 0-1 volt DC. It will bounce all around at idle and normal cruise, but under full throttle it will sit at a value closer to 1v.
                            I know its a shot in the dark, but did you touch your timing?
                              seanjohn
                              Nope, haven't touched the timing since the new dizzy...only thing to change is the 02 sensors. However, I double checked under my hood tonight because I have to order some
                              -an fittings for my fuel line...and I noticed it reaked of gas...and I notice a little pool of fuel accumulating on my intake manifold. Looked like it might have come out of injector #1....dunno if it's not getting a good seal or what?!?! Stoopid cars.
                                Who cares if the old o2 sensors have carbon? If they work better than the Bosch's, why don't you want to put them back in?
                                  if there is gas around it i would replace it just to be sure try that and see what happens then try the old o2 sensors in there again
                                    if youve R&R'd the injectors a lot maybe its a good idea to replace the O-rings...its a cheap insurance policy if nothing else...
                                      seanjohn
                                      Yeah, I'm going to go ahead and get a new injector o-ring set. The old 02 sensors have moved on to a better place. I'm going to replace them and the o-rings and see what happens.
                                        seanjohn
                                        FYI update: located the problem...it was a torn injector o-ring on injector #1. Cause: AEM fuel rail; as it turn out, the opening of the aim rail are not as large as stock, making the o-rings easily torn.
                                          Glad you found it. Good call Tony.
