  4. Manual Tranny Swap
Manual Tranny Swap
54 Posts 22 Posters 1.8k Views
    One of the big cost kickers is gonna depend on what you do for a clutch and flywheel.
      The crappy part is I don't want to put a used auto tranny into this car since the failure rate is absolutely ridiculous.
        I had the tranny in my 88 prelude swapped from auto to manual by Type-R about 5 years ago, so yes, people on here have had it done.
        I have also had my auto tranny built for about $1500 by Aamco and I have also had the high stall TC done by ProTorque. Depending on your reasoning for doing the swap (racing?) you might be better off doing a rebuild of the stock tranny w/ modified valvebodies and a high stall Torque Converter.
          Why not take your auto tranny apart yourself and fix it?
            assuming you yourself could do it, congrats. your probably the only person on fargostreet who can rebuild a tranny(correctly).
              Depending on your level of mechanical ability, I would guess that you could handle doing either of the swaps yourself. Replacing the auto at least would not be very difficult at all. They mostly just take time. It is too bad i didn't know about this earlier because i had a friend with a 5 spd accord that he was parting out and the motor was sold so he had everything for a manual and i would guess he would have sold it for under a grand for everything. But im pretty sure it is all gone now.
                You should buy a H22 full swap, then find some one who is parting out a 6g accord and get all the parts for the swap.
                I'm sure you can get all those parts call around mabye a junkyard near us have a 6g.
                • TsiTomT Offline
                  TsiTomT Offline
                  TsiTom
                  IF there are parts that are difficult to find for the swap...wouldnt certain prelude parts bolt right up??
                  Tom Opgrand
                  2011 Camry
                    I don't think there are too many rare parts at all. Everything seems to be readily available.
                    I wouldn't even consider touching a tranny myself.
                      i did/ am doing auto to 5-speed conversion. the hardest part is finding all off the parts.
                      you also could need differant cross members, brake pedal or assembly depending on how it is on the vehicle, shifter, shift boots, center counsel.
                      i have been buying parts when i see them for sale for over a year and on the last couple i am resorting to buying new. i didnt really have a set time i needed them so ive just been picking them when i see them and the motor is going back in in the next couple weeks so i just ordered new parts.
                        And dont forget swapping to a manual transmissino ECU also.
                          PSI2HI wrote:
                          You can find either a auto or manual trans for your Accord for under $1000 w/ around 50-60k or so on it.
                          I've found plenty of f23 manual trannies with around 50k for $350 while the remanufactured autos run about $1100 from what I've seen.
                            $100, but I don't think it's necessary for this swap.
                              Oh man pick that up! That's a start!
                                What do a decent clutch and flywheel go for? Under $500?
                                  Stock replacement = $125
                                  Stock use flywheel = $50
                                  Exedy stage1 cluch = $325 shipped
                                  Light weight flywheel = $275 shipped
                                  • wa2fastcamaroW Offline
                                    wa2fastcamaro
                                    Geez... there sure is some drama in this thread. I say if you have the time and a place, try to do it yourself. I have done plenty of auto to manual swaps and manual to auto swaps over the years. If you can find all the parts its fairly easy depending on the car. I am not fimiliar with your car really, but doing the swap should be just all mechanical parts, I don't think the wiring will matter, but I have run into cars that have to use a wiring harness for a manual car. Either way if you figure out what your doing, and need help or someone to do it for you, I am always up for a challenge. If you go with a new automatic, I could probally throw it in fairly reasonable too.
                                    Mike
                                    Boys and Their Toys Auto
                                    Phone: 701-371-5615
                                    E-mail: [email protected]
                                      Where is a decent place to look at and price used trannies? I've looking at car-part.com.
                                        Is the Exedy stage 1 organic clutch decent? Will it hold up spraying a 55-65 shot?
                                        How about an 8lb Fidanza flywheel?
                                        Any other suggestions for a clutch and flywheel in similar price ranges?
                                          car-part is probably the most consistantly inexpensive place to find parts
