  3. ICE and Detailing
  4. Soundproofing
Soundproofing
23 Posts 13 Posters 4.6k Views
  • 9 Offline
    9 Offline
    93Pgt
    I'm wondering if anyone has tried anything that works good in a hatch/trunk with a sub to reduce rattling and improve sound quality, ive heard of a few methods and id like to know what works good.
    thanks
      ive heard somethin about roofing material or somethin...otherwise you can go with the tried and true method: dynamat
        roofing material.... no matter which product or combination you try it will stink something terrible forever inside a car
          my buddy at work used it and hes got a pretty nice setup and it doesnt stink...he said its the exact same as dynamat...ill ask him on saturday exactly what he used...
            icedam or generic brand or any kind of foil type flashing uses tar... hard to believe it dont stink
              its exactly like dynamat...
              • J Offline
                J Offline
                JDMSTi
                www.b-quiet.com check that out....good site!
                  brownbread is good stuff, Vblock makes some nice stuff as well...no stench as it is not asphalt based. I can also get fairly easily the products on this page: http://www.theinstallbay.com/product_section.php?pn=22
                  Prices are anywhere from $6 to $100, depending on which kit you go with.
                  • krzydrftr93K Offline
                    krzydrftr93
                    Not sure if it works but I have heard of people using the truck bed liner crap(cant member the name of it) or that foam that puffs up and gets hard(I know people have sprayed this in cracks and panels)
                    Matt
                    92 Civic HB
                    JDM d15b w/14b@8psi
                      the spray in bed liner doesnt stop much of the rattling at least thats what ive been told. Ive heard spot welding works rather nicely though..
                        on my old grand prix i used expanding foam on the trunk and other spots were there was metal close together. but you have to hatk your time and do it right esspecially where it is visable. the stuff is ugly
                        • JohnWJ Offline
                          JohnWJ Offline
                          JohnW
                          I have used the following:
                          Brownbread: works the best IMO but stinks, also melts in the summer.
                          Cascade VB2: thin, works about as good as the brownbread, doesn't stink
                          B-quiet liquid: visoelastic sound deadener, has to be painted on in several layers with a long dry time between each, but is great for inner trunk panels, inside doors, wierd surfaces, etc.
                          Dynamat Extreme: the old standby, works well. expensive though. you can get more for less. you are paying for the brand name
                          Hitemp Mastic: 'Roofing stuff' god no. stinks like cat piss. alot. always. forever.
                          90 Civic DX hatch
                          D16a6/y8 mini me
                          • 9 Offline
                            9 Offline
                            93Pgt
                            thanks for all the info
                              I can get the cascade stuff as well I believe....
                                how much would a person need for an entire car?
                                http://www.raamaudio.com/ looking around I have found this site too.. seems to be different than tar-style. I think I might give this stuff a go.
                                  i've used brownbread, all types of dynamat....they both work well..
                                  i would never recommend using "great stuff" that foam that expands....
                                    http://www.s-f-d.com/pdf/casc.pdf
                                    let me know what you want, and I'll get you pricing.
                                    • 9 Offline
                                      9 Offline
                                      93Pgt
                                      how much is brownbread
                                        found a product from Dayton Audio that is vinyl based that I can sell for $25+ shipping for a 27"x40" sheet
                                        • TakeYourTopOffT Offline
                                          TakeYourTopOff
                                          When I did my Convertible that I used to do IASCA with I put v-block in it but it had areas that were hard to put matting down so I had put the spray on also and it held up for 6 years and the only time you heard rattle was if i had the trunk lid open and the rattle was from the part of the latch that grabbed the stricker!!!!
                                          legacy image legacy image
                                          Personal Web Site
