  4. amp has power but no sound coming out of sub
33 Posts 9 Posters 2.7k Views
  • T
    T
    Trafik Jamz
    Was it that long ago? Dang, thought it was last year sometime.
    LMK if I can be of any further help
    701.541.3484
    701.541.3484
    • theobliviousT
      theobliviousT
      theoblivious
      actually it was last summer. i keep getting my summers confused.
      BOOST....to be continued
      • BlueSRT0483B
        BlueSRT0483B
        BlueSRT0483
        Trafik Jamz;253601 wrote:
        No
        Turns on w/ ignition...receives signal through speaker level inputs or line output converter
        No....except maybe the fader being set wrong
        Not applicable
        Isn't that what 3 or 4 of us already suggested in some way shape or form? (though it is still good advice)
        --Not familiar with his deck, or didn't know of many with preouts.
        --Figured he was using a line out converter, and I'm not a big fan of them. Better off with a deck w/ preouts.
        --I should of expanded on what I was trying to get at with the wires. What I meant was for him to check not only the wires, but look over the terminals too. You have the terminals on the box, that may have a lose wire, or a lose terminal on the sub itself.
        2004 Dodge SRT-4
        ...Formerly "A853"...
        • theobliviousT
          theobliviousT
          theoblivious
          so i rewired everything on the audio side. (took out the wires from inside the sub, took out the wires connecting to the amp and the sub). I got the sub to turn on and play. however, when i turn up the volume up more than halfway, the sub cuts out and the amp goes into protection mode (red light turns on the amp).
          • theobliviousT
            theobliviousT
            theoblivious
            bump
            • wesholeW
              wesholeW
              Blown sub. 99% sure. Youll need to either measure the impedance of the sub or try another one to be sure.
              • T
                T
                Trafik Jamz
                blown sub or shorted wire (wires touching).
                701.541.3484
                • theobliviousT
                  theobliviousT
                  theoblivious
                  fixed the problem...my rcas were kind of bent out of shape, so i got a newer one. Seems to fix the problem nicely. Also, is a capacitor necessary when running an aftermarket amp? Will the sound quality be significantly improved?
                  Thanks again for all your help.
                  • wesholeW
                    wesholeW
                    Unless its a big capacitor, It does no good. A 2nd battery is a better option. But neither one will help in actual sound quality. It's more for making sure the amp(s) never run too low on power.
                    • BlueSRT0483B
                      BlueSRT0483B
                      BlueSRT0483
                      Your amp was pretty small right? Watt-age wise? I think you should be fine w/o one.
                      2004 Dodge SRT-4
                      • T
                        T
                        Trafik Jamz
                        Glad this was resolved.
                        As for the cap.....waste of money in every system on the planet....1000000% snake oil.
                        (and yes, i'm being serious when I say that)
                        701.541.3484
                        • wesholeW
                          wesholeW
                          What I cant figure out is if the rca's were bad connection wise, how did that put the amp into protect mode? Not typically something that you would see as a result of bad rca's.
                          • MisterCMKM
                            MisterCMKM
                            Chuck is a liar. I will sell you a 100 farad capacitor for the smoking deal of $100. 😄 jk, Chuck actually is right.
                            thrash;315544 wrote:
                            Ford is back :)
