  4. New Stuff
New Stuff
461 Posts 56 Posters 74.5k Views
    integra_gsr98;294196 wrote:
    My integra used to walk on rockets from a roll..... 550-600 hp and it's doable.
    video point of view ftw haha
    • zbrownZ Offline
      zbrownZ Offline
      King Ricer;294184 wrote:
      looks nice! so will the car be hitting the street/strip come spring?
      i dunno, need a rear end with gears first
      what did your car weigh at that time?
      KA-T_240;294227 wrote:
      I saw vids of this...
      they still around??
      rx7-8.89@157mph
      12v dodge, twins
        Looks good...but its still no Euro Track Car.
          zbrown;294234 wrote:
          they still around??
          I'm fairly certain I have it.
          Ok, looked, and don't have it so far.
            2650 with driver i suppose.
              with you or tufte in it 🙂
              • zbrownZ Offline
                zbrownZ Offline
                haven't updated lately... got the hotside minus the DP done
                everything is VHT and cured in an oven.... with the new DEI Titanium wrap.... shit is nice.... way nicer than anything else i have ever used, looks nice too
                oh, and i picked up a rear setup, so no more grenaded rear ends 😉
                rx7-8.89@157mph
                12v dodge, twins
                  me.
                  • beachbum_jonB Offline
                    beachbum_jon
                    care to elaborate on this?
                    -John Adams, 1735-1826-
                    • zbrownZ Offline
                      zbrownZ Offline
                      well after figuring out how much money it was going to be to work over my rear suspension with bushings, adjusters, rear steer eliminators, diff, moly axles.... it was going to be plenty of $$ and i don't want to have any chances of issues with an axle/joint breakage... tired of using only the inside 2" of my 10" tire too
                      So i picked up a new delux grannys 8.8 setup
                      See how i like it i guess, will be nice to get a 315 in the stock fender without notching the trailing arm too
                      i will weigh both the stock and granny setup with pics so we will see the actual weight difference too
                      will be quite the combo with a live axle and the Tein Flex coilovers, haha
                      this is a torque arm setup , so i wont bind like a 4 link or ladder bar setup and allow some body roll
                      this is the setup of the diff
                      -mustang 8.8 rear
                      -billet "Torino" style 9" housing ends
                      -5 lug 5 on 4-1/2" pattern w/ 2.60" center pilot
                      -forged 9" style 31 spline axles
                      -o-ring style 9" axle bearings and retainers
                      -3.27 ratio, 31 lightweight spool
                      yep... mullet me, but now i wont break anything
                      rx7-8.89@157mph
                      12v dodge, twins
                      • kylushK Offline
                        kylushK Offline
                        kylush
                        stupid rednecks investing in things that won't break....
                        1998 Z28 Camaro
                        • zbrownZ Offline
                          zbrownZ Offline
                          true that...
                          got my DP tacked up... fits like a glove which is surprising considering i did everything including TIG tack welding with chopper mittens and all in the lovely 0 degree weather
                          rx7-8.89@157mph
                          12v dodge, twins
                            zbrown;295588 wrote:
                            true that...
                            sounds like someone needs a heater in there shop, lol...
                            • zbrownZ Offline
                              zbrownZ Offline
                              how about even a heater...lol
                              i need to take it to the heated shop, but the cold weather just sort of took over all of a sudden and i had not moved it
                              rx7-8.89@157mph
                              12v dodge, twins
                              • thurmanmermanT Offline
                                thurmanmerman
                                true that...
                                Should have made all the bends out of pie cuts. Would have made 34.72hp more.
                                JK looks good
                                > Parker;299126 wrote:
                                • zbrownZ Offline
                                  zbrownZ Offline
                                  JK looks good
                                  ha, ya i pondered that.... but i don't have the required skillz
                                  Welded up my downpipe today, figured i would show you guys how i weld all my exhaust stuff.... This is with MIG (wirefeed) I trigger it and can keep a nice hot puddle without getting too hot on the thin aluminized tubing and yet have just the right amount of penetration on the inside.... gives it an almost TIG appearance
                                  I didn't TIG my V-band flanges on the DP because they are mild steel and not SS like on the up-pipes
                                  no brushing or grinding there, that is just how it looks when i get done, minus wiping it off with a rag.... start and stop right in the middle of the picture too
                                  rx7-8.89@157mph
                                  12v dodge, twins
                                  • inspector01I Offline
                                    inspector01
                                    Damn, that looks really good for MIG.
                                    PVC Squad Member #1
                                    • DrifterExtremeD Offline
                                      DrifterExtreme
                                      Looks good zac, for mig that is....:icon_geek:
                                      • zbrownZ Offline
                                        zbrownZ Offline
                                        I don't have the required skillz for TIG.... and it takes too long, lol
                                        rx7-8.89@157mph
                                        12v dodge, twins
                                        • ParkerP Offline
                                          ParkerP Offline
                                          Parker
                                          I see some splatter..... n00b...
                                          10 Jeep
                                          10 F450
                                          08 F250
                                          05 F350
                                          86 rx7
                                          70 F100
                                          63 Olds
                                          > BlueSRT0483;244555 wrote:
                                          > Trafik Jamz;260984 wrote:
                                          > You are right Parker.
