  4. New Stuff
New Stuff
461 Posts 56 Posters 74.5k Views
  • zbrownZ Offline
    zbrownZ Offline
    it would be embarrassing how slow i would go on that 114, truth, haha
    rx7-8.89@157mph
    12v dodge, twins
    • DaveHD Offline
      DaveHD Offline
      DaveH
      Your direct port spool up kit will be delivered later this week as well.
      DaveH
      '94 Supra- 7.77 @ 176mph
      • legacy-user-3898L Offline
        legacy-user-3898
        Does the pt114 spool that slowly?
        • zbrownZ Offline
          zbrownZ Offline
          Lol... well that seems to be what the fast guys do aye?? 😉
          Yeah they would use an F or G trim turbine at 130mm. It would roll once moving though haha
          rx7-8.89@157mph
          12v dodge, twins
          • zbrownZ Offline
            zbrownZ Offline
            and here is the idea, 3" of dust so maybe doesn't look the best in the pics but in real life really nice
            rx7-8.89@157mph
            12v dodge, twins
              looks great!!
              • 63vette6 Offline
                63vette6 Offline
                63vette
                Why did you put the axle ARB mounts on the front of the tube and not on the preferable location, the top?
                • zbrownZ Offline
                  zbrownZ Offline
                  King Ricer;327991 wrote:
                  looks great!!
                  Thanks man
                  No room. I wasnt going to cut the floor out of the car or i might aswell back half it
                  This is the one place possible to mount it and fit with the stock tank and no cutting on vehicle
                  rx7-8.89@157mph
                  12v dodge, twins
                    legacy-user-3898
                    are you going for more of a show car or race car? lol looks good tho
                    • zbrownZ Offline
                      zbrownZ Offline
                      probably a little beefy but happy with how it is in there
                      and wheel turned to lock
                      rx7-8.89@157mph
                      12v dodge, twins
                      • zbrownZ Offline
                        zbrownZ Offline
                        this big fucker came, it is way bigger than i thought it was going to be.... lucky it fits, sorta. haha
                        it weighs 46lbs, 29 of that is the turbine housing
                        the turbine is a bit ridiculous haha, 111mm turbine. has nice billet aluminum backing plate
                        also started on the charge piping. could of just got rid of the cross pipe, decided i wanted to keep it, i bent the pipe in where it is open flush with the channel iron and welded that too
                        charge pipe will come out of IC and up like so
                        rx7-8.89@157mph
                        12v dodge, twins
                          So does the car have more turbo than the truck yet?
                          • zbrownZ Offline
                            zbrownZ Offline
                            ha i made the cummins NA
                            love the way this turned out, makes me happy!
                            next is turbo, I am waiting on a t6 flange then it is game time
                            rx7-8.89@157mph
                            12v dodge, twins
                            • zbrownZ Offline
                              zbrownZ Offline
                              got alot done
                              first thing i did was build a drain box for the turbo, everybody likes a happy drainage, haha
                              here we have the intercooler setup done
                              turbo is all done and mounted, charge piping all done, intake done, exhaust is only thing left
                              on the charge piping i used hump hoses since the charge pipes are short and i use rubber engine mounts
                              i would usually weld the elbow on the turbo but i can pull the bearing housing and compressor out of the turbine housing if i would do that without dropping the IC
                              not a biggie i guess, just an extra coupler, haha
                              rx7-8.89@157mph
                              12v dodge, twins
                              • blackcherryTSiB Offline
                                blackcherryTSi
                                Your stuff is so badass! I wish I had a quarter or the skills and dedication that you have lol never seen a drain box before, any worries with it filling up faster then it drains them backing up into the turbo?
                                1995 Honda Civic
                                • zbrownZ Offline
                                  zbrownZ Offline
                                  thanks man
                                  na the box will help drain capacity, give it more degassing area
                                  and was worried about having a new converter, functioning transmission and how it would get up on the brake with this 111mm turbine
                                  well it makes boost so it is a good deal
                                  NA it stalls at 3200rpm, but i can get it up on the brake
                                  I let out at 10psi
                                  car feels like it is on a whole different level when this comes up
                                  https://www.youtube.com/watch?v=p6eDhrAx4qw&feature=youtube_gdata_player
                                  rx7-8.89@157mph
                                  12v dodge, twins
                                  • capitljC Offline
                                    capitljC Offline
                                    capitlj
                                    I bet it does, that's an awful lot of turbo in there.
                                    > Mitch Hedberg wrote:
                                    2004 Impala LS 3.8
                                    • legacy-user-351L Offline
                                      legacy-user-351
                                      Can't wait to see it run this summer!
                                      Turkeylord
                                      '05 Legacy GT Wagon - 5MT Stage 4e
                                      '05 Yamaha Zuma - Stock
                                      • zbrownZ Offline
                                        zbrownZ Offline
                                        thanks man, dont know if it will ever happen if i dont get started farming soon, haha
                                        I should never feel the need to upgrade the exhaust anymore lol
                                        With the charge piping gone I have an incredible amount of room on the passenger side
                                        It is 5" from turbo to fender. All 11ga aluminum. It will be stock quiet still when wanted because the full exhaust will still be there
                                        I don't have the cutout yet. I wanted a sound performance pneumatic one bit they only have 4". Race ready is the only 5" electric cutout around from what I see
                                        exhaust is stupid loud, triple what my old 3" dump was
                                        http://www.youtube.com/watch?v=HKN5Wv8QAnE
                                        rx7-8.89@157mph
                                        12v dodge, twins
                                        • zbrownZ Offline
                                          zbrownZ Offline
                                          rained tonight, had an hr to work on the exhaust
                                          rx7-8.89@157mph
                                          12v dodge, twins
