  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • zbrownZ
    zbrownZ
    it would be embarrassing how slow i would go on that 114, truth, haha
    • DaveHD
      DaveHD
      Your direct port spool up kit will be delivered later this week as well.
      • legacy-user-3898L
        legacy-user-3898L
        legacy-user-3898
        Does the pt114 spool that slowly?
        • zbrownZ
          zbrownZ
          Lol... well that seems to be what the fast guys do aye?? 😉
          Yeah they would use an F or G trim turbine at 130mm. It would roll once moving though haha
          • zbrownZ
            zbrownZ
            and here is the idea, 3" of dust so maybe doesn't look the best in the pics but in real life really nice
            • King RicerK
              King RicerK
              looks great!!
              Trafik Jamz;299122 wrote:
              • 63vette6
                63vette6
                63vette
                Why did you put the axle ARB mounts on the front of the tube and not on the preferable location, the top?
                • zbrownZ
                  zbrownZ
                  King Ricer;327991 wrote:
                  looks great!!
                  Thanks man
                  No room. I wasnt going to cut the floor out of the car or i might aswell back half it
                  This is the one place possible to mount it and fit with the stock tank and no cutting on vehicle
                  • legacy-user-3898L
                    legacy-user-3898L
                    legacy-user-3898
                    are you going for more of a show car or race car? lol looks good tho
                    • zbrownZ
                      zbrownZ
                      probably a little beefy but happy with how it is in there
                      and wheel turned to lock
                      • zbrownZ
                        zbrownZ
                        this big fucker came, it is way bigger than i thought it was going to be.... lucky it fits, sorta. haha
                        it weighs 46lbs, 29 of that is the turbine housing
                        the turbine is a bit ridiculous haha, 111mm turbine. has nice billet aluminum backing plate
                        also started on the charge piping. could of just got rid of the cross pipe, decided i wanted to keep it, i bent the pipe in where it is open flush with the channel iron and welded that too
                        charge pipe will come out of IC and up like so
                        • MisterCMKM
                          MisterCMKM
                          So does the car have more turbo than the truck yet?
                          thrash;315544 wrote:
                          Ford is back :)
                          • zbrownZ
                            zbrownZ
                            ha i made the cummins NA
                            love the way this turned out, makes me happy!
                            next is turbo, I am waiting on a t6 flange then it is game time
                            • zbrownZ
                              zbrownZ
                              got alot done
                              first thing i did was build a drain box for the turbo, everybody likes a happy drainage, haha
                              here we have the intercooler setup done
                              turbo is all done and mounted, charge piping all done, intake done, exhaust is only thing left
                              on the charge piping i used hump hoses since the charge pipes are short and i use rubber engine mounts
                              i would usually weld the elbow on the turbo but i can pull the bearing housing and compressor out of the turbine housing if i would do that without dropping the IC
                              not a biggie i guess, just an extra coupler, haha
                              • blackcherryTSiB
                                blackcherryTSiB
                                blackcherryTSi
                                Your stuff is so badass! I wish I had a quarter or the skills and dedication that you have lol never seen a drain box before, any worries with it filling up faster then it drains them backing up into the turbo?
                                1995 Honda Civic
                                • zbrownZ
                                  zbrownZ
                                  thanks man
                                  na the box will help drain capacity, give it more degassing area
                                  and was worried about having a new converter, functioning transmission and how it would get up on the brake with this 111mm turbine
                                  well it makes boost so it is a good deal
                                  NA it stalls at 3200rpm, but i can get it up on the brake
                                  I let out at 10psi
                                  car feels like it is on a whole different level when this comes up
                                  https://www.youtube.com/watch?v=p6eDhrAx4qw&feature=youtube_gdata_player
                                  • capitljC
                                    capitljC
                                    capitlj
                                    I bet it does, that's an awful lot of turbo in there.
                                    Mitch Hedberg wrote:
                                    2004 Impala LS 3.8
                                    • legacy-user-351L
                                      legacy-user-351L
                                      legacy-user-351
                                      Can't wait to see it run this summer!
                                      Turkeylord
                                      '05 Yamaha Zuma - Stock
                                      • zbrownZ
                                        zbrownZ
                                        thanks man, dont know if it will ever happen if i dont get started farming soon, haha
                                        I should never feel the need to upgrade the exhaust anymore lol
                                        With the charge piping gone I have an incredible amount of room on the passenger side
                                        It is 5" from turbo to fender. All 11ga aluminum. It will be stock quiet still when wanted because the full exhaust will still be there
                                        I don't have the cutout yet. I wanted a sound performance pneumatic one bit they only have 4". Race ready is the only 5" electric cutout around from what I see
                                        exhaust is stupid loud, triple what my old 3" dump was
                                        http://www.youtube.com/watch?v=HKN5Wv8QAnE
                                        • zbrownZ
                                          zbrownZ
                                          rained tonight, had an hr to work on the exhaust
