  4. New Stuff
New Stuff
461 Posts 56 Posters 74.8k Views
    zbrown;327986 wrote:
    it would be embarrassing how slow i would go on that 114, truth, haha
    Your direct port spool up kit will be delivered later this week as well.
    • legacy-user-3898L Offline
      legacy-user-3898
      Does the pt114 spool that slowly?
        Lol... well that seems to be what the fast guys do aye?? 😉
        Yeah they would use an F or G trim turbine at 130mm. It would roll once moving though haha
          and here is the idea, 3" of dust so maybe doesn't look the best in the pics but in real life really nice
            looks great!!
            • 63vette6 Offline
              63vette6 Offline
              63vette
              Why did you put the axle ARB mounts on the front of the tube and not on the preferable location, the top?
                King Ricer;327991 wrote:
                looks great!!
                Thanks man
                No room. I wasnt going to cut the floor out of the car or i might aswell back half it
                This is the one place possible to mount it and fit with the stock tank and no cutting on vehicle
                  legacy-user-3898
                  are you going for more of a show car or race car? lol looks good tho
                    probably a little beefy but happy with how it is in there
                    and wheel turned to lock
                      this big fucker came, it is way bigger than i thought it was going to be.... lucky it fits, sorta. haha
                      it weighs 46lbs, 29 of that is the turbine housing
                      the turbine is a bit ridiculous haha, 111mm turbine. has nice billet aluminum backing plate
                      also started on the charge piping. could of just got rid of the cross pipe, decided i wanted to keep it, i bent the pipe in where it is open flush with the channel iron and welded that too
                      charge pipe will come out of IC and up like so
                        So does the car have more turbo than the truck yet?
                          ha i made the cummins NA
                          love the way this turned out, makes me happy!
                          next is turbo, I am waiting on a t6 flange then it is game time
                            got alot done
                            first thing i did was build a drain box for the turbo, everybody likes a happy drainage, haha
                            here we have the intercooler setup done
                            turbo is all done and mounted, charge piping all done, intake done, exhaust is only thing left
                            on the charge piping i used hump hoses since the charge pipes are short and i use rubber engine mounts
                            i would usually weld the elbow on the turbo but i can pull the bearing housing and compressor out of the turbine housing if i would do that without dropping the IC
                            not a biggie i guess, just an extra coupler, haha
                            • blackcherryTSiB Offline
                              blackcherryTSi
                              Your stuff is so badass! I wish I had a quarter or the skills and dedication that you have lol never seen a drain box before, any worries with it filling up faster then it drains them backing up into the turbo?
                              1995 Honda Civic
                                thanks man
                                na the box will help drain capacity, give it more degassing area
                                and was worried about having a new converter, functioning transmission and how it would get up on the brake with this 111mm turbine
                                well it makes boost so it is a good deal
                                NA it stalls at 3200rpm, but i can get it up on the brake
                                I let out at 10psi
                                car feels like it is on a whole different level when this comes up
                                https://www.youtube.com/watch?v=p6eDhrAx4qw&feature=youtube_gdata_player
                                • capitljC Offline
                                  capitljC Offline
                                  capitlj
                                  I bet it does, that's an awful lot of turbo in there.
                                  > Mitch Hedberg wrote:
                                  2004 Impala LS 3.8
                                  • legacy-user-351L Offline
                                    legacy-user-351
                                    Can't wait to see it run this summer!
                                    Turkeylord
                                    '05 Yamaha Zuma - Stock
                                      thanks man, dont know if it will ever happen if i dont get started farming soon, haha
                                      I should never feel the need to upgrade the exhaust anymore lol
                                      With the charge piping gone I have an incredible amount of room on the passenger side
                                      It is 5" from turbo to fender. All 11ga aluminum. It will be stock quiet still when wanted because the full exhaust will still be there
                                      I don't have the cutout yet. I wanted a sound performance pneumatic one bit they only have 4". Race ready is the only 5" electric cutout around from what I see
                                      exhaust is stupid loud, triple what my old 3" dump was
                                      http://www.youtube.com/watch?v=HKN5Wv8QAnE
                                        rained tonight, had an hr to work on the exhaust
                                          finished up the rest of the exhaust, it is weird to hear the thing quiet. goes from stupid crazy to stock vehicle
                                          with the big ass thing open it is amazing how much still passes through the full exhaust, that surprised me
                                          also did something a little different as opposed to before, it pointed slightly down before and on a dirty road or gravel the exhaust blow dust up and piss me off
                                          so it is pointed up now
                                          all i got left is working on the front end and plumbing the IC
