New Stuff
thanks man, i am excited too
it will be interesting because it is amazing the car was running what it was as is.
anyone there saw me puking oil on the topend and roasting my fluid, and pushing through the converter
well problem was the stator support tube was pressed into the pump clocked wrong and the one oil passage was completely blocked off
meaning no oil could leave the converter, haha
looks nice. any idea's what size turbo your going to go with? i upgraded mine to a borg warner st80. did you make the rear sway bar yourself?
Does the pt114 spool that slowly?
DaveH;327987 wrote:
Your direct port spool up kit will be delivered later this week as well.
Lol... well that seems to be what the fast guys do aye??
90rs&01rs;327988 wrote:
Does the pt114 spool that slowly?Yeah they would use an F or G trim turbine at 130mm. It would roll once moving though haha
looks great!!
King Ricer;327991 wrote:
looks great!!Thanks man
63vette;327992 wrote:
Why did you put the axle ARB mounts on the front of the tube and not on the preferable location, the top?No room. I wasnt going to cut the floor out of the car or i might aswell back half it
This is the one place possible to mount it and fit with the stock tank and no cutting on vehicle
are you going for more of a show car or race car? lol looks good tho
this big fucker came, it is way bigger than i thought it was going to be.... lucky it fits, sorta. haha
it weighs 46lbs, 29 of that is the turbine housing
the turbine is a bit ridiculous haha, 111mm turbine. has nice billet aluminum backing plate
also started on the charge piping. could of just got rid of the cross pipe, decided i wanted to keep it, i bent the pipe in where it is open flush with the channel iron and welded that too
charge pipe will come out of IC and up like so
got alot done
first thing i did was build a drain box for the turbo, everybody likes a happy drainage, haha
here we have the intercooler setup done
turbo is all done and mounted, charge piping all done, intake done, exhaust is only thing left
on the charge piping i used hump hoses since the charge pipes are short and i use rubber engine mounts
i would usually weld the elbow on the turbo but i can pull the bearing housing and compressor out of the turbine housing if i would do that without dropping the IC
not a biggie i guess, just an extra coupler, haha
