  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • GarageAlchemistG
    GarageAlchemistG
    GarageAlchemist
    Looks beast, as usual. Where are your coils hidden?
    97 GTi, 03 KJ
    • zbrownZ
      zbrownZ
      they are in mah cubby hole
      you are going to have to get used to that whole 8 coil thing, lol
      • zbrownZ
        zbrownZ
        and here is part of the plan so the fuel pressure sender is hidden and doesnt have to be down hanging off the regulator
        • zbrownZ
          zbrownZ
          • zbrownZ
            zbrownZ
            well got my breathers and FPR done. i am waiting for a special order bend still to complete the passenger side rail > fpr line
            I use all Earl's stuff now
            engine bay hasn't been cleaned yet from last fall so, yes its dirty
            -12 from each valve cover to exhaust valves
            -6 from each rail into the FPR, -8 to the tank
            and here is where the fuel pressure sender ended up
            • zbrownZ
              zbrownZ
              The one harness really has bothered me for a time, so i ran alot of the wires under the intake to hide them, required some grinding
              and then i put the correct terminals on for the injectors so that i didnt have to use the gayass adapters and chance a blown engine when one fucked up
              also used good mesh looming
              from this
              to this
              • legacy-user-3898L
                legacy-user-3898L
                legacy-user-3898
                looking good. when i did mine i ran wire's under the intake and tryed to keep it looking clean
                • zbrownZ
                  zbrownZ
                  just gonna update some stuff
                  turbo is sold, dont know the replacement
                  no more rock chips
                  working on making the engine bay look nicer, the are not done
                  new big boy 9.5" ptc
                  and roll bar time, wanted something could bolt in and out and serviceable, no modding to tank mounting or anything
                  • M
                    M
                    mat50ho
                    Wire clean up Looks nice, I am intrestead to see how the new converter works...
                    89 Mustang coupe
                    • zbrownZ
                      zbrownZ
                      thanks man, i am excited too
                      it will be interesting because it is amazing the car was running what it was as is.
                      anyone there saw me puking oil on the topend and roasting my fluid, and pushing through the converter
                      well problem was the stator support tube was pressed into the pump clocked wrong and the one oil passage was completely blocked off
                      meaning no oil could leave the converter, haha
                      • zbrownZ
                        zbrownZ
                        may be rice, but this excites me
                        • legacy-user-3898L
                          legacy-user-3898L
                          legacy-user-3898
                          looks nice. any idea's what size turbo your going to go with? i upgraded mine to a borg warner st80. did you make the rear sway bar yourself?
                          • zbrownZ
                            zbrownZ
                            thanks
                            yeah i built the bar, got the parts for it off mcmastercarr. love that place
                            mmm turbo will still probably be an 88 compressor, just bigger turbine, probably gt55 size turbine
                            i am a turbo whore, that is the only reason i am changing haha
                            • DaveHD
                              DaveHD
                              Your PT114 is scheduled to be delivered today, I'll get it shipped out to you this afternoon.
                              • zbrownZ
                                zbrownZ
                                it would be embarrassing how slow i would go on that 114, truth, haha
                                • DaveHD
                                  DaveHD
                                  Your direct port spool up kit will be delivered later this week as well.
                                  • legacy-user-3898L
                                    legacy-user-3898L
                                    legacy-user-3898
                                    Does the pt114 spool that slowly?
                                    • zbrownZ
                                      zbrownZ
                                      Lol... well that seems to be what the fast guys do aye?? 😉
                                      Yeah they would use an F or G trim turbine at 130mm. It would roll once moving though haha
                                      • zbrownZ
                                        zbrownZ
                                        and here is the idea, 3" of dust so maybe doesn't look the best in the pics but in real life really nice
                                        • King RicerK
                                          King RicerK
                                          looks great!!
                                          Trafik Jamz;299122 wrote:
