  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • integra_gsr98I
    integra_gsr98I
    Did you finish the front half of the cage yet?
    • zbrownZ
      zbrownZ
      No
      I received my halo and A pillar bars. The halo fits nice, I don't like the A pillar
      So it wont be done till I buy a bender, don't know when that will be
      • DaveHD
        DaveHD
        I added all of my 25.5 bars myself, I just used a piece of 1/4" rod and bent it over my knee to make a pattern of the pipe I needed made, then brought the rod with me to the guy with the mandrel bender and had him make what I needed. You just need to find someone out in the backwoods where you live that has a bender. 🙂
        • zbrownZ
          zbrownZ
          sadly no one around here does. it is going to stay as is until i get my own bender 😞
          • zbrownZ
            zbrownZ
            changing a little bit of stuff
            had a Magnafuel 625 (4301), and now got a new 750 (4303). This will support over 1kwhp on E85. Good pumps
            and i plan to move my regulator up front at the same time trying to keep it not a hose monster. we will see how that goes
            • zbrownZ
              zbrownZ
              gonna be along the lines of like this
              and breathers, adding a -12 to each valve cover, and it will go back to the exhaust valvers with braided SS.
              here is the baffles i added, this is the one in the valvecover i added last year. I added the same thing to the other side now with the addition of the other breather
              • GarageAlchemistG
                GarageAlchemistG
                GarageAlchemist
                Looks beast, as usual. Where are your coils hidden?
                97 GTi, 03 KJ
                • zbrownZ
                  zbrownZ
                  they are in mah cubby hole
                  you are going to have to get used to that whole 8 coil thing, lol
                  • zbrownZ
                    zbrownZ
                    and here is part of the plan so the fuel pressure sender is hidden and doesnt have to be down hanging off the regulator
                    • zbrownZ
                      zbrownZ
                      • zbrownZ
                        zbrownZ
                        well got my breathers and FPR done. i am waiting for a special order bend still to complete the passenger side rail > fpr line
                        I use all Earl's stuff now
                        engine bay hasn't been cleaned yet from last fall so, yes its dirty
                        -12 from each valve cover to exhaust valves
                        -6 from each rail into the FPR, -8 to the tank
                        and here is where the fuel pressure sender ended up
                        • zbrownZ
                          zbrownZ
                          The one harness really has bothered me for a time, so i ran alot of the wires under the intake to hide them, required some grinding
                          and then i put the correct terminals on for the injectors so that i didnt have to use the gayass adapters and chance a blown engine when one fucked up
                          also used good mesh looming
                          from this
                          to this
                          • legacy-user-3898L
                            legacy-user-3898L
                            legacy-user-3898
                            looking good. when i did mine i ran wire's under the intake and tryed to keep it looking clean
                            • zbrownZ
                              zbrownZ
                              just gonna update some stuff
                              turbo is sold, dont know the replacement
                              no more rock chips
                              working on making the engine bay look nicer, the are not done
                              new big boy 9.5" ptc
                              and roll bar time, wanted something could bolt in and out and serviceable, no modding to tank mounting or anything
                              • M
                                M
                                mat50ho
                                Wire clean up Looks nice, I am intrestead to see how the new converter works...
                                89 Mustang coupe
                                • zbrownZ
                                  zbrownZ
                                  thanks man, i am excited too
                                  it will be interesting because it is amazing the car was running what it was as is.
                                  anyone there saw me puking oil on the topend and roasting my fluid, and pushing through the converter
                                  well problem was the stator support tube was pressed into the pump clocked wrong and the one oil passage was completely blocked off
                                  meaning no oil could leave the converter, haha
                                  • zbrownZ
                                    zbrownZ
                                    may be rice, but this excites me
                                    • legacy-user-3898L
                                      legacy-user-3898L
                                      legacy-user-3898
                                      looks nice. any idea's what size turbo your going to go with? i upgraded mine to a borg warner st80. did you make the rear sway bar yourself?
                                      • zbrownZ
                                        zbrownZ
                                        thanks
                                        yeah i built the bar, got the parts for it off mcmastercarr. love that place
                                        mmm turbo will still probably be an 88 compressor, just bigger turbine, probably gt55 size turbine
                                        i am a turbo whore, that is the only reason i am changing haha
                                        • DaveHD
                                          DaveHD
                                          Your PT114 is scheduled to be delivered today, I'll get it shipped out to you this afternoon.
